Nov 13, 2023 19:46:43 GMT
Nov 13, 2023 20:17:26 GMT
Easiest way would be too mount the pump via rubber insulation and leave connections the same.
jimi
Nov 13, 2023 22:48:04 GMT
Easiest way would be too mount the pump via rubber insulation and leave connections the same. only if the metal pipework isn't directly connected to the pump, i.e needs to insulated from the pump body with a short pieces of rubber/plastic hose. 😉 Personally I'd swop the pump to a negative earth one.
Last Edit: Nov 13, 2023 22:51:57 GMT by jimi
Nov 13, 2023 23:35:28 GMT
Had a similar issue earlier this year on my Cambridge. Bought a good second hand pump from eBay fitted with an electronic unit, but it turned out to be positive earth and they are not changeable. £80 for a new neg earth electronic unit was the only option.
Last Edit: Nov 13, 2023 23:36:02 GMT by misterm
'57 Austin Cambridge A55 1800 Overdrive '50 MG Y-type (In build) '56 Standard Super 10 (In build) '03 Fiat Stilo Abarth (Wet weather runabout) '03 Citroen Berlingo HDi (Parts hauler)
Thanks all. Think with it being a fuel pump and risk of sparks will buy a neg earth and maybe we'll on the pos earth pump.
madmog
Club RR Member Number: 46
SU fuel pump polaritymadmog
@madmog
Club Retro Rides Member 46
Nov 14, 2023 17:45:16 GMT
Perhaps send off a message to Burlen/SU, quoting the number on your fuel pump and seeing what they say. I know they have electronic points conversions for existing pumps and perhaps that is a way to change polarity.
Nov 14, 2023 17:59:35 GMT
I've got a new one coming but thanks. Will see if I can sell on the positive earth one as it's only done 500 miles according to the receipt and car mot history with the mileage.
