anyone got a man cave big enough??
www.facebook.com/marketplace/item/1126886515389199/
Up for sale is a stage prop chitty chitty bang bang.
This was built for a series of shows and is now taking up storage space so either needs to be dismantled or moved on to a new owner.
Designed and built in 2022/2023 she is an amalgamation of the film car and various stage versions.
She is about 3.5m long and 1.3m wide (small enough to fit through a double door) and is packed with features listed below. Built on a custom aluminium frame with solid connection points to bolt into the flying arm (available separately) or to be re-mounted on a scissor lift to create the flying car scenes.
Fitted with seat belts she can operate on the flying or stand alone.
Fully controlled by Wireless DMX she has the below movements:
Windscreen lifts and tilts flat, 2 channels
Horn, 1 channel
Front wing extends through the number plate, 2 channels
All 4 wheels have individual drive motors (one needs repair)
All 4 wheels lift to approximately 90 Degrees, 2ch each (rear needs repair) Pins also lock these in place when moving on normal wheels.
Both side wings open, 2ch Each
Rotors hidden in each wing Lift, Open and Spin, 5 Ch each.
Float Boxes Lower and then float extends. SL installed and works (SR is not currently installed but could be, All items supplied), 5 Ch Each
All Lights work, list includes (two headlights, 2 front face lights, 2 wing lights, 2 rotor lights, 2 rear face lights, 4x led lights on wheel arches.(2x Side lamps pictured are not included in the sale but can be for extra negotiation) wiring will be left in place. All light are individually controlled Via DMX.
There is an extra foot with a set of swivel castors that can be lowered to enable the car to be moved around by hand and in any direction.Controlled via a switch on the dashboard.
Steering works and there is a fwd/revers switch on the dash,and a foot pedal for local control.
Seating for two adults and two children in the car, it was tested on the flying rig made for it to a load of 700KG but was never used with more than 450Kg
Its generally made of aluminium and powder coated, she looks amazing and I'm gutted to be selling her but unfortunately she has to move on,Really hope someone can make use of her. The whole car runs on 24V DC power from 2 sealed batteries, and has a charger included.
Price listed it the minimum the parts of the car are worth to me. So unfortunately, if she does not sell I suspect we will end up breaking her down to reclaim the components parts.
There is a full flying arm available for her, this is basically a traveling counterweight dolly with a boom arm mounted on a lift tower, It is pictured in some images but is not for sale as part of this package,it is available but would be a separate discussion.
Delivery we can arrange but is not included, she will fit in a luton van easily and would possibly go into a large panel van. Currently located in PE19 postcode area.
Please feel free to contact me with any questions. she is also listed on Facebook and a few other places and has a few videos to show her in action.
BBC Article here: www.bbc.com/news/uk-england-cambridgeshire-67194493
Insta link here:
www.instagram.com/reel/Cyg1sFgMjN7/?utm_source=ig_web_copy_link&igsh=MzRlODBiNWFlZA==
Ebay Link: www.ebay.co.uk/itm/145532636610 See less
Horn, 1 channel
Insta link here:
