LowStandards
Dec 25, 2007 14:05:08 GMT
Right, I know dash all about springs, but I'm wanting to drop my Commer a good 2 inches at the front. I'd be happy enough to cut them, but as I want all my mods reversible (she's in near mint nick) I'd be best just buying some new springs! Now obviously you cant get a lowering kit for the ode PB1500, so I'm gonna have to figure out spring rates and thickness etc, here's where you lot come in Explain...
rysz
Dec 25, 2007 14:12:03 GMT
Get the dimensions of the current spring in its free state off the car.
The dimensions that you need are:
Free Length (End to End) Inside diameter / Outside diameter Wire diameter Number of coils
Then, how low do you want to go? How much do you want the stiffness uprated by?
Dec 25, 2007 14:41:17 GMT
Best thing is to ring a custom spring manufacturer. 9/10 times they'll know roughly what you're looking for out of experience (as long as you choose an experienced one).
You tell them I have a commer camper, i want to drop it 2 inches while keeping some ride comfort, what do you recommend?
LowStandards
Dec 25, 2007 15:00:17 GMT
I've ordered 2inch lowering blocks for the rear, so i'm wanting to go 2inches att he front!
There's a place local to me that does kitcar stuff, but it appears to be run by a bunch of retards, so i could do with asking for exactly what i need!
Dec 25, 2007 15:08:39 GMT
I thought all these Commers had the rear axle under the springs and therefore lowering blocks are not going to work.... I don't know if there's enough arch to the leaves to get them reset lower by a couple of inches As rysz said, unless you find someone familiar with Commer coil springs you'll need to measure yours to sort out the drop on the front.
LowStandards
Dec 25, 2007 15:34:01 GMT
I thought all these Commers had the rear axle under the springs and therefore lowering blocks are not going to work.... Dammit, I guess i should really of looked at that hey... Best get in the Garage to find out! There's plenty of arch gap in there, i've already lowered her about 3 inches by binning the commercial tyres and fitting some low profile ones (no pics i'm afraid) This makes her look a lot better, but still doesn't change the relation of wheel-to-arch gapage...
Dec 25, 2007 15:56:40 GMT
if the axle is below the leaf spring, then you can usually put the axle above the leaf to drop it the width of the axle casing.
or get the leafs decambered.
LowStandards
Dec 25, 2007 15:58:19 GMT
That would be another good 3inch drop, might have diff to body clearance issues... I guess i best get under her with the ode tape measure...
Dec 25, 2007 21:37:40 GMT
Yeah, he put the axle above the leafs and notched the chassis. Not a 2-minute job I'm sure. Its all documented in readers rides if you have a dig.
LowStandards
Dec 25, 2007 21:53:39 GMT
Yeah, i've seen that, wanted a simplier way to be honest
LowStandards
Dec 26, 2007 14:22:08 GMT
Right, just found some info on a Commer related site. The front is nice and easy, a coil lopped off drops about 2inches. The rear can be dropped very easily by removing leafs from the spring pack (I think there's 7 in all)
This is where the info gets a little sketchy, its says that some of the leafs do the height and some do the bounce (if you know what i mean) But doesn't say which do what.
Does anyone have much experiance of leaf spring packs that could steer me into the right direction, i'll reward your efforts with pics of my hardslammed vanage in the new year
