tigran
In rust we trust. Amen.
Club RR Member Number: 142
Triumph 1850 oil leak Qtigran
@tigran
Club Retro Rides Member 142
Just a quickie really. The dolly is dripping (in the same sense that niagra falls is a drip) out oil. But it's in such a bizarre place - I swear it's dripping out from between the bellhousing and the block. It's deffo Oil and not ATF btw.
What the fugg is going on? Or is this a well versed thing in Triumph circles? I mean it's the least of my worries on the car - but every little helps.
IDY
I swear it's dripping out from between the bellhousing and the block. I know nothing about dollys but if it was a Sierra I would suspect the rear crank shaft seal
I will get round to finishing it at some point
tigran
@tigran
Thing is - it drips even when it hasn't been turned over in months. Surely there's no standing oil in there?!
**just to add**
although thinking about it if the engine was overfilled with oil it might explain it?
*a confuzzled tig*
Last Edit: Jan 28, 2008 5:46:42 GMT by tigran
Whip the gearbox off and find out, only way to be sure, and if it is the rear crankshaft seal you'll have to take it off anyway.
Faster. Faster. Until the thrill of speed overcomes the fear of death.
tigran
@tigran
Whip the gearbox off and find out, only way to be sure, and if it is the rear crankshaft seal you'll have to take it off anyway. Yeeeah, problem with whipping an auto off (as i've found out with the auto on my capper) is that autos are an utter PITA to mate up back to the flywheel. I'll get some sort of workshop manual for the dolly and investigate methinks.
