Jan 30, 2008 19:40:57 GMT
I could try and knock up a couple of plates on the mill... how does 4deg sound? ;D Need to find a stub axle to experiment with I reckon 4deg is about right TBH....id give you a stub if i had one kicking around Scrapyard? If you do manage to knock out a decent set i might have to commision a pair
Your car is not 'epic', this thread is not 'epic'....the OCEAN is epic, the UNIVERSE is epic.... please stop misusing this word!! It would appear Hotrods are the new VWs - aint fashion funny! '69 BUICK LESABRE 350
Jan 30, 2008 19:41:18 GMT
And I suppose once you get into silly camber (like 3deg plus) you need to think about plates for the bolts heads to seat on the other side as well.
Jan 30, 2008 20:05:40 GMT
And I suppose once you get into silly camber (like 3deg plus) you need to think about plates for the bolts heads to seat on the other side as well. I think you could probably get away with 5-7deg with a few fibre/rubber washers under the bolt head. 4 deg is not alot really
rodit
Jan 30, 2008 20:23:44 GMT
Would be avoiding washers guy's it really aint going to give the strength bit like using wrong stud pattern wheels on standard bolts. Another option is something we uese at work some time's supplied by super tracker ( 4 wheel alignment supplier), it is a camber toe adjustment plate and is a fiber plate that works in much the same way as the shim you pictured, eccept it is cut out at set places to suit your requirements by yourself. Hope this may be of some use to maybe the non ford guys?
Low and slow
Why can't i tune it?
Jan 30, 2008 20:28:54 GMT
Would be avoiding washers guy's it really aint going to give the strength bit like using wrong stud pattern wheels on standard bolts. Another option is something we uese at work some time's supplied by super tracker ( 4 wheel alignment supplier), it is a camber toe adjustment plate and is a fiber plate that works in much the same way as the shim you pictured, eccept it is cut out at set places to suit your requirements by yourself. Hope this may be of some use to maybe the non ford guys? Where can you get these? would like to know more ;D *edit: these guys? www.supertracker.com/accessories.htm
Jan 30, 2008 20:44:31 GMT
Jan 30, 2008 21:00:10 GMT
I ran purpose-made shims on the back of my lowered GLSi. Basically the four bolts holding it are not 2 at the top 2 at the bottom they are 1 at the top, 2 either side, 1 at the bottom. The shims were U shaped, you put 2 at the top, and 1 either side. If I was doing it again I'd just use washers in the same ratios. To increase the camber put them at the bottom and the sides.
On the Sierra you apply some serious torque to the bolts so they shouldn't move.
I know I'm old and boring but a word of warning. Without the shims it ate tyres (as in shot to pieces after about 2000 miles). And the handling was as twitchy as curse word in the wet. With even more neg on it those problems would be exacerbated.
One other thing, if you're going to use that big 1-piece spacer thing, youll need to pull the driveshaft completely.
Jaguar S-Type 3.0 SE
Jan 30, 2008 21:10:35 GMT
Cheers for that keithyboy, the more and more I research it, the more and more apparant it becomes that washers will probably be fine.....my car doesnt do more than 80mph, I NEVER have anyone on the back seats (its more a 2+2 than a 4 seater IMHO as only a child or midget could fit LOL), and its light as hell so wont be taking much strain. Oh and its FWD so just trailing arms. I think ill be okay with a couple of washers stuffed in i don't intend to be ragging it around a track anytime soon either
Jan 30, 2008 21:28:36 GMT
Johnny, lovely thread you dug up there.
They don't seem to realise that people want cars for more than just going flat out round a track.
Hands up who's bought trainers but never planned on running a marathon?
Back on subject.... was planning to give the rear brakes on the Polo a going over soonish so I'll have a look and see what can be done then. I think 4deg will be plenty for me tbh!
rodit
Jan 30, 2008 21:35:45 GMT
Those are what i was meaning, think they are about £20 a set and seriously worth using. Insurance even allow us to use them rather than write off a rear beemed car with minor tolerance issues.
Low and slow
Jan 30, 2008 21:45:57 GMT
You'll have to be carefull using them shims backwards, they correct the toe in you get on the rear when lowering a sierra as well as the excessive camber so you'll be suffering toe out as well, i give your rear tyres 1000 miles if your lucky with em fitted the wrong way.
My lowered XR4x4's (without shims) were wearing tyres to the metal on the inside 2" in about 1500 - 2000 miles and they only do 66% of the work on a 4x4.
Jan 30, 2008 21:50:30 GMT
Those are what I was meaning, think they are about £20 a set and seriously worth using. Insurance even allow us to use them rather than write off a rear beemed car with minor tolerance issues. Just in case the washers end up being too precarious, where can i get some of these?
rodit
Jan 30, 2008 21:56:05 GMT
Just look for your nearest local garage or body shop that has super tracker alignment gear they should be able to get em for you, or try them direct on line, usually pretty helpfull people.
Low and slow
This thread has thrown up some interesting stuff and after reading that Jeek from tramp drift uses washers on this 24v saff drift car, I am quite willing to give washers ago to see how they are.
After all I have never reinforced my rear turrets when I fitted the coilovers and I was told by some scare mongers that I would punch two holes in the boot as soon as I lowered it back down........ er 6000 miles later they are fine no sign of cracking or damage at all!
Good luck johnny 5-6 neg camber would look insane on the back of the datsun!!!!!!! Yo!
Good luck johnny 5-6 neg camber would look insane on the back of the datsun!!!!!!! Yo! You motherflippin knows it yo!
want camber? ;D both the polo and the datty would look good with some camber. what sort of camber have you guys got on the front?
got absolutley ZERO camber on the front due to the way the suspension is i did lay it on the ground for the laugh once (no pics before you ask) and the wheels were still bolt upright! LOL Think just the back 'toe'd' out would be friggin ace tho
Me? Enough to wear the tyres but not enough to be visible. About the worst combination. And it isnt adjustable in any way.
Grr!
