I have a g40 engine, which comes with a FVWSH.
I brought the engine with 60k on the clocks, it has only 10 k since then.
It comes with the engine, ecu with a sns chip, standard intercooler, charger (fully blend), 65mm and 63mm pulley, it has a flowed throttle body and manifold. Induction kit, heat sheild, charger collor, a extra set of brand new charger belts. The charger had a rebuild only 5k miles ago. Does not use oil what so ever its a really good engine.
The engine does not come with a gearbox as I'm using that with my next engine.
But you do have all the parts needed to a engine conversion you just need a gearbox to get it running.
I'm looking around £800 for the above.
