Jan 13, 2007 21:43:52 GMT
Nissan Sunny JN10 ZX Coupe Engine
Complete (red rocker) 16v Engine, coilpack, inlet, exhaust and loom ecu included if needed, all out of a '92.
Its a 1600, runs sweet
£45
Pickup in ipswich
Tillio Race Prep and Spares Ltd
Oval racing Rollcage fabrication from £250.....Track car builds, engine conversions etc...
Jan 14, 2007 13:50:54 GMT
Might be worth you posting this on www.zxoc.co.uk BTW, that model will be a B12 not JN10. I'm guessing you got JN10 off the chassis number?
Jan 14, 2007 18:55:50 GMT
Ratdat, your correct!
Not used to J cars, it does have JN10 on the chassis number!
Thanks for the link
Jan 14, 2007 19:17:50 GMT
The chassis number begins JN10 yeah? It's a standard 17 digit VIN number. The first two digits JN just signifies the car is built by Nissan Japan (if it was SJN it would be Nissan Sunderland) Wikipedia has a good explanation of that system. Not that it's particularly useful info but thought i's post it anyway. By the way, in case anyone fancies this for a RWD swap. It will fit mounted RWD bolted to either a Silvia or 200SX geabox. This is a 1.6 version of the CA18DE but it uses a variable intake runner system to give it a bit more bottom end (it runs as a 12 valve under 4000rpm and a 16 valve above). Power is 120bhp @ 6600rpm and torque 102ft/lb @5600rpm. They redline at about 7500rpm.
Jan 14, 2007 19:22:32 GMT
Crikey, you know your stuff then! With that in mind........ Will a 1.3 or a 1.4 8v engine out of an early sunny (g plate) bolt straight in? the engine and box mounts, along with the engine bay look identical, only difference being it has a hydraulic clutch? Any idea?
Jan 14, 2007 19:30:23 GMT
So long as you have the mounts that go with the engine you intend to use and it came from either a B12 or N13 sunny then it'll bolt in. The B12 coame as the coupe like yours or a fastback estate, though they aren't all that common. The N13 is a hatchback or saloon with a boot and was sold at the same time as the B12. You could use any of the engines that came in these cars. If i remember rightly, the clutch master just bolts into the same hole as the cable comes though in the bulhead. I think even the hole in the pedal arms is there for it.
Jan 15, 2007 10:32:29 GMT
By the way, in case anyone fancies this for a RWD swap. It will fit mounted RWD bolted to either a Silvia or 200SX geabox. This is a 1.6 version of the CA18DE but it uses a variable intake runner system to give it a bit more bottom end (it runs as a 12 valve under 4000rpm and a 16 valve above). Power is 120bhp @ 6600rpm and torque 102ft/lb @5600rpm. They redline at about 7500rpm. ARGH! Brain melt....
Jan 16, 2007 13:51:42 GMT
By the way, in case anyone fancies this for a RWD swap. It will fit mounted RWD bolted to either a Silvia or 200SX geabox. This is a 1.6 version of the CA18DE but it uses a variable intake runner system to give it a bit more bottom end (it runs as a 12 valve under 4000rpm and a 16 valve above). Power is 120bhp @ 6600rpm and torque 102ft/lb @5600rpm. They redline at about 7500rpm. ARGH! Brain melt.... Just buy it and stick it on those TB`s ;D
Jan 16, 2007 14:14:24 GMT
Just buy it and stick it on those TB`s ;D It had occured to me that I might get to use them finally We'll see.... no idea how to get it,.. no idea how to fit it ,.. but luckily I have a great bunch of people surrounding me to help out on all fronts
Jan 16, 2007 14:23:00 GMT
This ain't the engine for TB's unfortunately. if you wanted to go with TB's you'd probably have to change the head for a four port one.
Jan 16, 2007 14:27:03 GMT
Oh well,.. something to consider for the future,.. I don't have the engine yet (I'm just assuming its still available),.. and its about as far from being in the car as its possible to get
