Kris
Does anybody have a VAG parts microfiche list/program/pdf file?
I am trying to find out the offset of the front discs for:
239mm VW Golf GTi discs and
239mm Audi Coupe 1.8 discs.
I want to know if I'm able to fit the discs from my Golf to my mates Audi Coupe. They are the same diameter and pcd.
GSF list them seperatly but I have a feeling that they are the same parts.
Last Edit: Feb 21, 2005 10:48:37 GMT by Kris
Feb 21, 2005 11:33:22 GMT
ETKA reports that the front brake disks (239mm, 20mm wide, 4x100, ventilated) are the same part number on the 1988 Golf GTI as they are on a 1986 Audi 80. Note that Audi 90's of the same year used 256's or 245's so not to use them. Make sure they're ventilated though cos some Audi 80's used 12mm thick solid discs. FYI they're both pn 321 615 301 edit - just noticed you said it's a coupe... same applies if it's the PCD are the same, some 5cyl models used 4x108. Same part number for a 4cyl 1986 model though.
Last Edit: Feb 21, 2005 11:35:10 GMT by Pillock
Never trust a man Who names himself Trevor. Or one day you might find He's not a real drug dealer.
Kris
Feb 21, 2005 11:49:50 GMT
Cheers boss.
We are going to put the discs and pads from my dead Mk2 on his Audi, they have only done about 1000 miles.
His is the 1.8 and has 4x100 PCD and vented discs.
I just wanted to check as another mate was going to put 260mm Granada discs on his 260mm braked Sierra, as they were half the price, but there was 4mm more offset on them, just thought it maybe the same case with the Audi and Golf.
