HytestA
Cant beat a good bit of rubbing :D
Feb 21, 2005 18:32:28 GMT
I get confused with wheel fitting, so heres a question for you clever bods. I'm going to put the standard BBS alloys back on my Polo, and was wondering if the Anteras I'm taking off will fit on an Astra Mk2. The PCD is the same but does that mean they will work or do I also have to look into the offset of the wheels etc. Sorry for being so thick ;D
Feb 21, 2005 19:12:52 GMT
Missus has a SEAT which is same fitment as 4 stud VW, which I'm 99% sure is same as Vauxhall & a few others aswell. The offset may not be exact , but is as near as dammit.
Feb 21, 2005 19:19:43 GMT
Feb 21, 2005 19:42:15 GMT
Feb 21, 2005 19:50:02 GMT
have seen mk2 astras with mk2 golf steels if thats any help
2001 HONDA CT110 (NOT RCV)
Feb 21, 2005 20:38:32 GMT
IIRC fwd Vauxhalls have a 50mm offset. (feel free to flame if I am talking curse word)
Feb 21, 2005 21:05:08 GMT
It's the centre bore you want to be careful about.
Wheel fitting questionrustingdeathtrap
@GUEST
Feb 21, 2005 21:28:29 GMT
IIRC fwd Vauxhalls have a 50mm offset. (feel free to flame if I am talking curse word) I think its 48mm and on a mark2 astra you've gotta be spot on cos of the rear arches covering the wheel. Best bet is to just try em and see.
Feb 21, 2005 21:44:02 GMT
I think its 48mm and on a mark2 astra you've gotta be spot on cos of the rear arches covering the wheel. Best bet is to just try em and see. Think you're right about that, actually... Although some jucious use of hammer / grinder on the arches will soon cure it! I did this on my old Mk2 Astra Estate so I could bang on some 15inch steels...
Feb 21, 2005 22:33:53 GMT
Its a +39 offset. Awkard as f£$ck, cos if it isnay right they will eat wheellbearings at a staggering rate!!!
i remember this from my days of reading max power... (when VB-H used to write!)
Vauxhall is a +38 or +39 offset, but is designed to form part of the suspension geometry or summat which means if you deviate too far from this, your car will handle like mega-poo (even more than vauxhalls usually do). Also the squared-off arches will be a problem, but are easily rolled.
VW fitments are between +35 and +45, the +35 you should be fine but the +45 end will be pushing it, are there any marks on the Anteras to show what they are?
Never trust a man Who names himself Trevor. Or one day you might find He's not a real drug dealer.
HytestA
Feb 22, 2005 10:51:26 GMT
VW fitments are between +35 and +45, the +35 you should be fine but the +45 end will be pushing it, are there any marks on the Anteras to show what they are? to be honest I couldnt tell you, I've never taken the Antera's off since I got them fitted, the only time they came off was to get new tyres fitted and that was done by the fitters I'll remove the centre caps and take a look under there, might be something. Cheers for all the replys Guys, mucho appreciated
Kris
Feb 22, 2005 12:10:14 GMT
I know its not really to do with this thread but the Transit Connect wears some fat 5-stud steels, saw one this morning. I like the big arches too.
Feb 22, 2005 17:21:51 GMT
Offset is usually stamped on the inside (back) of the spokes along with wheel width.
