yoeddynz
Oct 31, 2007 19:27:40 GMT
For my new HB Viva project i need...
A front cross member with the discs ....(mines still drums all round)
A six dial dash outta one one of the bigger engined cars?
Some red leather recaros or something simular...in red...and leather..
An ignition switch with key
thank you please
alex
pbottomley
If at first you don't succeed, then skydiving isnt for you
Six dial dash was only used in the GT, good luck chap, and expect to pay TOP DOLLAR for it, better and cheaper to fit diasl in a centre consol
kevfromwales
may be able to get the disc front end, can you pm me your location please, as I'll need conformation that it's what you want before I go and chop it out! - kev
pbottomley
CHOP it out? it bolts in with four bolts and the steering coupling ?? Two bolts vertically through chassis rails next to engine mounts, two bolts through chassis rails under doors and a couple of wee nuts on the steering coupling. Thats it... NO CHOPS required. Ive offered to Help yoeddynz out with finding the parts, so quick question for you, what is this front subframe off? If its off a HB and or a HC, jobs a good one, if its off a HA will not be what yoeddynz wants. If it is off a HA then others will be just as intrested Wink Wink
