lol @ black rims they are midnight putple same as the car,
but i agree in the pics they look very very black, they have to e i nthe sunlight to really see the colour
DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS
My Cars Web Site 86motorsport.com/
Apr 11, 2007 21:58:29 GMT
fitted in last 7 months full prothane bushing kit water and oil temp, oil pressure and volt guages fixed my dash fixed dash lights light weight alternator pulley twin electric fans, along with a thermostatic controll switch in place of viscous 4 point harness'es sorted all cabling out greddy radiator pipe TRD 2Way LSD Helix cerametalic Paddle clutch and larger 212mm flywheel new CROWN and Pinion battle version steering spacer kit painted alloys some slight bodywork repairs cusco gearbox mount TRD engine mounts also bought a new front bonnet bumper and wings a wee vid oh yeah and BTW that noise at the start is the electric fans lol
Apr 25, 2007 18:53:48 GMT
well the MoT is tomorrow as 12 lunchtime front bumper is on along with the sidelights and here is the tow vehicle a vauxhall frontera 2.8tdi will do a better job than my 1.6 8v VW jetta lol
Apr 26, 2007 17:33:29 GMT
well the MoT was today and she passed 2 advisories front drivers tyre is near legal limit which i knew about anyway and divers front balljoint very very slight play cracked my front bumper tryingto get it onto the trailer first time round, some bricks and planks of wood went on no problem not really to bothered will get worse damage when i com off into the kitty litter whilst learning t drift lol
Davenger
It's only metal
Club RR Member Number: 140
Oooof Keep showing me porn like that, and I will misplace my yoghurt. Awesome looking car dude, so glad it passed it's MOT
Apr 27, 2007 22:39:37 GMT
i am glad she passed as well just waiting on my insurance docs now so i can tax the car then run the diff in and drive her the way she is supposed to be sideways got a box today had something i have wanted since i bought the car can yoiu guees what it is yup standard wing mirrors to get rid of the nice gay M3 ones ebay bargain at £30 went and got a price for getting the bonnet sprayed £150 this includes geetting the bonnet done getting the headlight covers redone wings blended in and mirrors painted getting it a bit cheaper because my mate works there guy that done my MoT
This is how its done!... Top stuff...
May 24, 2007 15:21:26 GMT
well here is an update for you all the car is not back on the road yet as i had hoped ran into a problem where the car was not acclerating right, or going hrough the rv range quick enough, we thought it was an ignition problem so changed the leads/dizzy cap/rotor arm/plugs this did not sort the problem so next thing we checked was the timing which was out slighlty, after we sorted thiswe could not even get the car to start, so next up was a compression check which gave these results here are the figures dry 1 130 3 155 2 103 4 112 wet 1 135 3 163 2 120 4 132 according to the books min is 142 and max 179 with a max of 14psi differance so strip the head off to discover one curse word head gasket and once curse word cylinder number3 and a curse word piston so i ordered a new TRD 0.8 metal headgasket as it was cheaper than a standard one it got delivered by a courier but it was fcuking well folded in half contacted fensport they went apeshit and are sending me a replacment asap in the meantime i have decided to scrap my engine as it is an early model 3rib big port engine going to go with an engine from a AE92 FWD corolla as it is the later 7rib smallport engine so better for further modification in the future all that is left to go is the gearbox now and when that goes i am fitting a supra box instead of the T50 as it is cheaper and stronger
May 24, 2007 18:45:50 GMT
bad news on the engine, but good news I guess cos you can replace with later one. The small port is the non-TVIS injection eh? Should be fairly easy to get hold of too. Don't forget to turn the inlet round though, as the throttle body will be on the wrong side when its mounted longditudinally. although I'm guessing you know that What else you gotta do to get a FWD 4age into a RWD 86?
May 24, 2007 19:05:15 GMT
bad news on the engine, but good news I guess cos you can replace with later one. The small port is the non-TVIS injection eh? Should be fairly easy to get hold of too. Don't forget to turn the inlet round though, as the throttle body will be on the wrong side when its mounted longditudinally. although I'm guessing you know that What else you gotta do to get a FWD 4age into a RWD 86? the earlier oens still came with T-vis which i what i want not ready to ditch the tvis just yet as my ecu would have a hissy fit, and would have to fit an aftermarket one need water pump and all water ancilieries and stuff off of my old engine to mount it for RWD and yeah she does look nice and mean
well should be getting hold of a replacment engine soon, thank feck going to rebuild it with all new parts water pump oil pump ACL RACE SERIES Crankshaft Main Bearing Set Standard Size (5M1695H-STD) ACL RACE SERIES Connecting Rod Bearing Set Standard Size (4B1780H-STD) ACL RACE SERIES Thrust Washer Set Standard Size(2T1695) cgi.ebay.com/ebaymotors/88-CHEVROLET-NOVA-1-6L-DOHC-16V-ACL-RACE-BEARINGS-4AGE_W0QQcmdZViewItemQQcategoryZ33619QQihZ007QQitemZ170092348882QQtcZphotofull engine full gasket set ARP flywheel bolts(already got these) new pistons, and piston rings(standard) new plugs new timing belt and fan belt TRD 0.8 metal headgasket going to be about £200 for all the parts majority of parts are coming from america planned mods PASS racing underdrive pulley kit lightweight one peice illegal garage driveshaft lightweight 212mm flywheel
ok some new parts arrived today A'PEXi power intake SARD Magnetic Oil plug TRD horn button also my TRD 0.8 Metal Headgasket arrived raises the compression some got a new set of drift rims as well ordered the ACL Bearings, and new pistons and rings from america £121 delivered also ordered the ARP Flywheel bolts Dad has gotten me an engine from ebay £68 perfect for full rebuild going to see how much to get the crank lightened and balanced as well the workshop lol cam covers have been painted same colour as the car they look black in the pic however lol
J.P
I like to eat ice cream and I really enjoy a nice pair of slacks.
Plenty of Nice parts there! Lets get drifting!
looks great mate, cant wait to see it done!
The journey of 1000 miles starts with a single coffee.
I don't like coffee!
Jun 13, 2007 22:09:07 GMT
ARP flywheel bolts turned up
just trying to source an oil pump from a AE101 levin now, thats the 20v silvertop 4age has higher presure and flows more, only prob is enever done this car in the UK
also trying to get hold of some TODA valve springs whilst i have the engine stripped down this far
gettinf the flywheel and crank lightened and blanced as well £50 plus vat
trying to source a ARP bolt kit for the engine as well for a reasonable price
most of my parts are coming from america
Jun 16, 2007 20:25:58 GMT
well collected my engine from preston 199.9 miles down and the same back left at 3:30 pm got there at about 7:15 pm left an hour later and got home at 12:45am my 1.6 mk2 jetta wasnt to keen on the hills on the way back haha with trailer and engine on tow 64k 7rib engine assuming it is a redtop as it has red cam lettering seems in pretty good nick, has new dizzy cap, rotor arm, leads, and plugs, t-vis also looks new but thats not much use to me. still waiting on parts to arrive befre the rebuild can start anyone know of the MR2 or AE86 crank is better? anyway here are some pics
Jun 18, 2007 10:11:48 GMT
a box arrived for me today after paying te £33.03 charge to parcel force robbing curse word my ACL race bearings and pistons and piston rings
Jun 19, 2007 20:29:50 GMT
well i think something is missing from the picture below anyone guess what it is and here is some of what is missing here this is the fubared one clutch and flywheel removed as that is what i need off of that block everything else is being replaced with new 212mm flywheel and a helix paddle clutch so waiting on gasket set an AE101 oil pump to arrive ands then thats everything
Jun 19, 2007 20:42:52 GMT
Also think i have settled on what route i am going to go with my engine going to stick with the 16v 4A-GE, but aiming for 200bhp This will be acheived using mainly TODA components but with a few other manufacturers as well the P.A.S.S racing lightweight underdrive pulley kit store.autosportsupplies.com/merchant2/merchant.mvc?Screen=PROD&Store_Code=PASS&Product_Code=SPP01-AC&Category_Code=EPillegal garage one peice lightweight prop forums.club4ag.com/zerothread?id=5600Lightweight Flywheel, possably toda but not sure yet lighten and balance crank, flywheel and the AE86 high cam computer KIT. (STAGE-III Type 200PS) Price: $4500 Kit contents (1)TODA forged piston set (ø81.00mm / ø81.25mm / ø82.00mm) (2)High power camshaft IN 280 (10.3) x1 EX 288 (10.5) x1 (3)Adjustable cam pulleys x2 (4)Inner-shim KIT (5)TODA Fuel computer.(Standard computer trade-in) (6)Fuel MAP switch ( fuel control) with fuel regulator (7)Sports injection KIT Adjustable cam pulleys x2 Up rated valve springs set Option : Ignition timing MAP switch (for Ignition timing control) the TODA kit comes to about £2260 everything else is about £1500 including mapping which should see in excess of 200bhp
Jun 20, 2007 20:45:38 GMT
someting missing from the trailer hmmm oh wait here it is started stripping the engine down today removed ancileries before we put it onto the stand accordig the cambelt covers it was last done at 91k miles so i think it has done 164k and not the 64k he thought lol got the camcovers off and what an intersting state the head is in oil is bloody solid, think i might use the old head as it seems to be in betetr condition, will decided once the head is completely cleaned up cams seems a little rusty as well some random MR2 engine parts that will soon make there way to ebay asa brucey bonus i now have a spare 212mm flywheel didnt know the Mr2's came with them
