Jun 21, 2007 20:26:36 GMT
glad i got the engine cheap as all i am using is the block not happy with the rest cylinder head bolts are blue from heat, think it has been given a roasting at some point, not happy with the crank, there is a mark on it that has left a score in the coresponding bearing shell. so pretty much all i am taking from this is the block, and nothing else ok so here we are so far ACl Race bearings + Pistons/piston rings delivered from america £121 engine £68 Toyota Genuine Gasket set AE101 20v oil pump PASS Racing underdrive pulley kit all £350 delivered from america Water Pump £35 spark plugs £20 Timing belt £20 TRD 0.8mm Metal headgasket £50 plus getting the flywheel and crank lightened and balanced tomorrow charging £50 plus vat, done some name dropping for that price
DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS
My Cars Web Site 86motorsport.com/
J.P
I like to eat ice cream and I really enjoy a nice pair of slacks.
Jun 21, 2007 21:28:53 GMT
Serious amount of bits going into that engine! Niiiiice.
Jun 26, 2007 16:43:45 GMT
tidied the block up a little bit along with the sump and engine mounts need to decided what colour to paint the engine bay white or black white to spot leaks etc black to make it blend in with the paint a bit more i hate the contrast of the red against the paint, prob hate the white even more :? conrods are off getting lightened and balanced with the crank and fly now also ordered all the parts for my new filter set up
Jun 26, 2007 22:23:32 GMT
you could try for silver, or maybe even whatever the complementary colour is to the actual car colour.
The journey of 1000 miles starts with a single coffee.
I don't like coffee!
st182
'yota man
Jun 26, 2007 23:29:07 GMT
black engine bay FTW- then no matter what colour you decide to paint the car / engine in the future, it creates no problems Great work sir, keep it up- shame the engine was a little pooped tho
Dan '93 JZA80 '79 TA40 '99 SCP10
Jun 27, 2007 17:23:17 GMT
you could try for silver, or maybe even whatever the complementary colour is to the actual car colour. colour of car here a dark midnight purple think a grey colour could be good, because it is still dark and will belnd in betetr than white plus still be able to spot any leaks
Jun 27, 2007 18:14:37 GMT
yup, thats the sort of thing I'm on about. Grey/silver, dark metallic grey/silver would look good, again, you'd still be able to see the stains (should it leak!)
Jun 28, 2007 20:15:50 GMT
updated spec list
should stay like this for a while, while i save more money up haha
Engine 7 Rib Big Port Engine Apexi AFC ISKY Racing Cams Adj Fuel regulator Uprated fuel pump 4-1 manifold Straight through underaxle exhaust A'PEXi power intake SARD Magnetic Oil plug Grex Oil Cooler greddy radiator pipe TRD Engine mounts AirCon removed Viscous fan removed and twin electric fitted TRD Rad Cap Lightened and Balanced Crank Lightened and Balanced Conrods Full Fresh Rebuild AE101 Oil Pump for beter flow TRD 0.8mm Metal Headgasket P.A.S.S Racing Underdrive Light Weight Racing Pulleys ACL RACE SERIES Crankshaft Main Bearings ACL RACE SERIES Connecting Rod Bearings
Transmission TRD Quick shift Helix Cerametalic Paddle Clutch TRD 2 way Limited Slip Differential Cusco Gearbox mount Lightened and Balanced Flywheel ARP flywheel bolts
Suspenion Front CoilOvers Cusco Topmount Camber Adjustment Rear TRD adjustable shocks and Springs 'Achieve Sports' Full Roll Cage Alloy RCA's Adjustable Rear Lateral Rod Front Strut Brace Full Poly Bush Kit (just fitted)
Brakes Uprated Brake Rotors and Blitz Pads new rear discs Cusco Brake Enhance
Exterior Extreme Dimensions Body Kit TRD Spoiler 14” Celica Supra Alloys, Painted Same as car Front 14x7 rear 14x7
Interior Standard Seats from a later spec 1986 car MOMO 4 point harnesses MOMO Wheel and extended hub Fully stripped Oil Pressure Guage Oil Temperature Gauge Volt Gauge Water Temp Gauge All AutoGauge Smoke series
Steering Battle Version Steering spacer Kit2
Jun 30, 2007 13:37:34 GMT
my gaskets, oil pump, and racing pulleys are in the country, i know this because i just got another curse word letter from parcel force asking me for more curse word money, the vat was fine £13.55, its the parcel force curse word handling fee i hate £13.50 silly-billies
Gasket set A101 oil pump and my P.A.S.S Racing underdrive pulleys arrived yesterday so the rebuild can commence on the engine at curse word last haha Also purchased something else that I will not be able to use for quite a while, but could not pass them up at such a bloody bargain price of £370 for the pair TRD cam shaft. Modifyed (machined) to run High RPM intake is 312 dur 11 lift(discontinued from Japan) exhaust is 304 dur 11 lift cant use them yet as need serious head work, and aftermarket managment also updated my cars website www.86motorsport.comonly been about 8 months lol
Fantastic stuff as ever,.. will we see this out and about this summer (What there is of it!?)
yeah once the engine is rebuilt, give that about another 2 weeks, then i will be doing to 1000 mile run in
probably going to do a run down to bristol and back up again, thats about 800 mile round trip right there
once thats done i will be going to teeside for soem drift events
OK small update my dad has just informed me that the new conrod bearings that we have are to big, the ACL racing ones these are the ones i went for cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&viewitem=&item=170119319611 and they are bigger than the ones that we took out the engine and they don't fit so engine rebuild just ground to a halt, till new ones are sourced, curse word the new bearing from what my dad tells me it measures 43mm old one measures up at 41mm Also spent some more money and bought these £130 delivered from america not a bad buy i thought haha so the mental cams combined with these ITB's and my car should sounds rather tasty
pauld
keep up the the good work
#OLD IS GOOD#
AMAZING, nice to see some serious work going on and some dead posh engine parts too!
As always keep us posted, I loving your car and after watching Inital-D a few nights ago I really, really, really, really, really, really, really, really, really, really, really, really, really, really, really, really, really, really, really, really want an AE86!
Jul 13, 2007 19:08:46 GMT
Finally got the new bearings and the rebuild has re-comenced had to go with ACL heavy duty rather than the ACL race bearings, but they are the next best thing anyway. pistons are now back at home in the block where they belong and also managaged to get the engine bay painted black so blends i na bit more than the red lol
Jul 17, 2007 16:11:50 GMT
well the block is now attached back to the bellhousing and is bolted back in to the engine mounts just need to put the head back on and then connect everythnig back up one problem is we lost all the pics as the PC shat a brick and wiped the hard drive, shame just need to read the manuals now lol anyway some pics an engine lift might have helped but i did not know we were ready to lift engine in lol so had not organised one oh well, we just manhandled it in
Jul 27, 2007 18:07:14 GMT
box arrived today after i had paid the import charges that is, robbing bastards it contained these whats this bit for :wack: ITB's froma 20v silvertop 4age wont be getting fitted till next year though no cash for the managment to run them lol as for an update on the car check this thread haha www.driftworks.com/forum/technical/39383-ae86-starting-issue.htmland sounds something like this
been a while since an update so here you go small update on this, after many months of being curse word off with the car it is now here Untitled DocumentHypertech in central scotland, guy is an ex toyota mechanic. the engine was rebuild and refused to start, this was a good few months ago now, eventually got fed up so put it into garage valve timing was the problem car now starts and idles, but touch the throttle and it cuts out, so will have the car back next week, awesome just have the run in on the engine to do now and i just wanna cry lol ------------------------------ picked up a new pair of rims for the car impul pro mesh's 14x7 with 5" of dish £120 car is still in the garage, seems there were a few other issues other than timing, a partially blocked fuel system, ignition timing, and a few other niggle bits and pieces, so hopefully back soon
picked up a new pair of rims for the car impul pro mesh's 14x7 with 5" of dish £120 ( Love it on the current rims but those new cats are beautiful! Where did they come from at £120? They are dish-city!
