boxerman
I simply love Alfa boxers
Aug 22, 2007 21:10:35 GMT
today i've purchased another Alfasud it's an '82 alfasud Ti 1.5 95bhp a bit of welding required for the APK, the dutch equivalent of the englisch MOT technically this sud is sound, so no brake-issues ;D the exterior is pretty 'ratty' , i'll leave it that way some pics a previous owner had already done some welding, but after grinding the welds smooth, did nothing to it so that has to be done again
Last Edit: Oct 2, 2007 19:58:03 GMT by rmad
PSST, I know my english is bad, but why don't yo try talking Dutch
1982 Alfasud Ti 1.5stealthstylz
@stealthstylz
Club Retro Rides Member 174
Aug 22, 2007 21:12:51 GMT
Get a wire brush fitted to an angle grinder on the rusty welds the metal might come up OK. Suds are cool cars my mates dad had one when I was little the handling was immense.
Matt
boxerman
Aug 22, 2007 21:43:06 GMT
biggest problem is that the previous repair is scraping the door so it'll have to come out again and redone properly this time
harry
Aug 23, 2007 10:41:37 GMT
i love suds, my dad had probably 7 or 8 over the years when i was growing up. i've been on the lookout for a reasonably priced., but not totally rusty one for ages
Shortcut
I won't be there when you cross the road, so always use the Green Cross Code.
Aug 23, 2007 11:13:15 GMT
Hey an old mate of mine had a Sud. It was waay cool. He bought it from a main dealer. It was 18 month old and we were so jealous as the rest of us could only afford old bangers. He was pleased as punch it was so cheap for a practically new car.
Upon inspection. 18 month old and already rusting away!!! It lasted until it's first MOT.
[edit] not scrapped just had to sell it for virtually nothing as he couldn't afford the welding it needed to pass.
Last Edit: Aug 23, 2007 11:14:14 GMT by Shortcut
This space available to rent. Reach literally dozens of people. Cheap rates!
boxerman
Aug 31, 2007 18:46:28 GMT
I have started the welding on the sud first took out the door and the frontwing and attacked the rust with the wirebrush on the anglegrinder. than I patched up the outersill. not to look good, but just for strength. next was the innersill/floorpan joint also patched up now all the welds and bare-metal is covered in primer tomorrow i'll seal the welds off and put the wing and door back in
Last Edit: Aug 31, 2007 18:48:33 GMT by boxerman
gearoil
Projectless...
Sept 1, 2007 12:09:48 GMT
All good there mate, another car on the 'wanted' list!
Sept 1, 2007 14:38:57 GMT
Hmmmmmmmm Good going there.
boxerman
Sept 10, 2007 18:57:00 GMT
Took the sud home last weekend, carefully driving around until I find a bit of time to get it tested ;D changed the wheels to original green cloverleaf wheels, I wanted to put 15"on, but they didn't fit in the rear arches, the sud is to low also did some finetuning on the carbs, idled at 1800rpm now idles at 800rpm and runs much smoother
Last Edit: Sept 10, 2007 19:00:06 GMT by boxerman
Sept 10, 2007 19:07:37 GMT
nice looking sud you have there keep us updated on your car.
boxerman
Sept 15, 2007 19:38:33 GMT
the Alfasud failed the test unfortunately so i have been busy with it today to make the list a lot shorter, I had some welding to do on the floorpans, i had hoped it would have been an advisory, but it was a fail also started to clean up the brakediscs, the sud had been stored outside for over a year and a half, so they were rusty the rears have been done today, fronts are not so fine to do on the floor, so i will do that on a lift or so... pic's
boxerman
Finally had the time for a re-test, and it passed next weekend i'll change the cam belts and tensioners, and the fluids en filters of course after that it's about time to start with the exterior, some holes waiting for some fresh metal
boxerman
May 28, 2008 21:11:01 GMT
my Alfasud is still going strong, i've been busy collecting bits for it, and found almost everything.
- OMP strutbrace - OMP rollcage - Sparco bucketseats - MOMO steeringwheelboss, and MOMO Corse steeringwheel - Goodridge braided brakehoses - new brakediscs and pads front and rear - yellow koni adjustable shockabsorbers front and rear - polycarbonate for the widewindows - yellow headlights - 1.7 carbsengine - shorter Ti QV gearbox - K&N open airfilters - complete CSC exhaustsystem - new radiator - 6Jx15 ET18 5 spoke mille-miglia wheels, will be painted white
so it will be in the workshop for some work, after that i will use the alfasud for trackdays/fun
That sounds like a great selection of bits you've got to go in your Sud Looking forward to seeing some pictures when its all put together
starchild
suck/squeeze/bang/blow.
May 29, 2008 20:00:48 GMT
i had a sud once 5 dr 1.5 loved driving it but it had no t&t,i didnt appreciate it then,i wish i kept it longer.there sooper dooper motors,love it.
richie
May 29, 2008 20:17:05 GMT
Ive always wanted one of these, but never been brave enough to risk the rot issues. Great project.
boxerman
May 29, 2008 20:50:57 GMT
LOL, suds tend to rot a bit that's for sure but the handling is superb
i have to put some pictures online, then i'll post them here
not sure what to do with the body, there's a few rustholes in it, actually quite a lot holes ;D should i repair that, or leave it as rusty as it is floors, innerwings and sills are all very solid, so it will pass the test anyway
and if i should repair it, i'm thinking of making wide arches in metal like lancia delta integrales
but for now i will first put all my attention to the mechanical side of it
boxerman
May 31, 2008 20:57:19 GMT
the alfasud is inside the workshop now, had to turn everything upsidedown to create a nice workspace, and took pictures but i forgot to take the camera back home so pics will follow
