MR TIKI
TIKI,style from a different angle!
Feb 20, 2008 21:04:48 GMT
Last Edit: Mar 31, 2020 19:44:57 GMT by MR TIKI
Boldly driving faster than a tin worm can wiggle.
MR TIKI
Feb 21, 2008 18:13:57 GMT
Neat! Mini tiki heads are very cool. Too fragile for gear shift? Any going spare?
Feb 22, 2008 10:17:06 GMT
Ace top works, really comes alive finished. Cars are the only thing i didn't do in ceramincs, needed a switch off from em. Will post a few up later.
MR TIKI
Feb 22, 2008 12:43:41 GMT
Neat! Mini tiki heads are very cool. Too fragile for gear shift? Any going spare? the mini Tikis are shot glasses,trinket pots and cocktail stick holders.I make them for fish tanks too.I see no reason why you can't make a solid ceramic shifter knob,never thought about it before.sadly,I'm not in a position to make these on a commercial basis they are just a hobby.I'm looking into getting a small kiln at home so I can produce them for sale in the future.
Feb 22, 2008 12:57:04 GMT
My class was working out £10 for a 3 hour slot, not very commercial for making to sell, which isn't why I was there. Gearknob is a great idea! how would you do it,? cos it would shrink. put a nut in there with it in the kiln, leave a big hole for a rubber bunged threaded nut type thing? or summat else?
Feb 22, 2008 13:40:33 GMT
what about making it round a metal tube, then once baked, just tap the tube out to the correct thread??
MR TIKI
Feb 22, 2008 13:45:51 GMT
My class was working out £10 for a 3 hour slot, not very commercial for making to sell, which isn't why I was there. Gearknob is a great idea! how would you do it,? cos it would shrink. put a nut in there with it in the kiln, leave a big hole for a rubber bunged threaded nut type thing? or summat else? my biggest worry would be trapped moisture or air bubbles in the clay.solid objects can explode in the kiln if they aren't dried properly or have bubbles in them.I think the best way to get around the issue of fitting a ceramic gear knob would be to air dry the work with a pre made hole around the right size then bore it out enough to take a rubber sleave ie; some fuel pipe allowing for any aditional shrinkage.once its properly dry the clay won't skrink a great deal in the kiln but it would be best to go oversized,you can always fill the hole with resin then drill it after its fired.
MR TIKI
Feb 22, 2008 13:55:12 GMT
what about making it round a metal tube, then once baked, just tap the tube out to the correct thread?? in theory thats not a bad idea but, clay shrinks during the firing process and it would probably blow apart or at the very least crack because there would'nt be any give in the metal.
Last Edit: Feb 22, 2008 13:57:59 GMT by MR TIKI
Feb 22, 2008 14:27:08 GMT
Good idea, I never got involved in the drying out process, just left it for the technician to eventually put in kiln! right i'll see what i got in Photobucket...
MR TIKI
Feb 25, 2008 20:45:21 GMT
kiln fresh and begging to be filled with a double rum'n'coke on the rocks! ;D
Feb 25, 2008 22:47:32 GMT
Got a bigger pic of that one on you Avatar?
MR TIKI
Feb 25, 2008 23:11:53 GMT
Got a bigger pic of that one on you Avatar? thats a 'faux Moai' concrete garden ornament I bought years ago.I have them around the house as door stops.the orginal picture from the Uxbridge auto show is on the album link below. www.photobox.co.uk/album/5663532there is some other work on here,made by people in my art classes at work. www.photobox.co.uk/album/7671496
Last Edit: Aug 1, 2008 22:22:04 GMT by MR TIKI
Feb 25, 2008 23:13:42 GMT
Ah cool, thats a real funny face!
MR TIKI
Feb 28, 2008 19:45:57 GMT
''Too fragile for gear shift?'' asked seth,''only time will tell!'' replied MR TIKI. inspired by the 5 little words above from seth I've been experimenting. wet clay prototype TIKI shifter. dried,etched,buffed and ready for the kiln. its now being fired........
Last Edit: Feb 28, 2008 19:47:37 GMT by MR TIKI
Feb 29, 2008 14:10:12 GMT
Ace! nice glossy glaze on there or summat more textured for grip, could be fantastic finishing pice for the TIKI Mobile! Watch the orders flood in now! ;D
Tim
Feb 29, 2008 14:16:26 GMT
My dad has one of those heads at home - made from wood. Used to be great for halloween :-)
MR TIKI
TIKI SHIFTER II. wet clay fired and awaiting glaze.
MR TIKI
Last Edit: Dec 30, 2008 23:25:33 GMT by MR TIKI
Tefal
TIKI FTW
