Just doing a few jobs on the BMW and I noticed this Is it just sound deadening or is it heat related? If it needs to be there is there something easy/more modern/more effective I can replace it with? All ideas appreciated
slater
Club RR Member Number: 78
Under Bonnet Foamslater
@slater
Club Retro Rides Member 78
Its just sound deadning relly
Under Bonnet Foambriandamaged
@GUEST
Stick some of that green imitation grass they use in butchers' shops on there. Add some sausages/pork chops for a tasty trackday BBQ. ;D
GJM
Alloy engines; like communism- great in theory.
Crabon monoxide with your smoked bacon vicar? ;D
What they all mean is - take it out and clean it off, you'll be fine!
The journey of 1000 miles starts with a single coffee.
I don't like coffee!
Dynamat and other brands do "Underhood insulation" which is similar but better than the hair stuff. The hair stuff can fall off in lcumps down your carb and block it up... Meh. Even if it doesn't it seems to be always full of dirt and stuff which falls in your hair or into the carb. gittish stuff. The dynamat is nice and shiny too (aluminimum or similar backing is used)
mercmad
Flush Hard,it's a long way to McDonalds.
Just look up a Motor trimmer wholesale supplier in the yellow pages or google and buy a under-hood mat. it comes in a large square. you just cut it to shape with scissors then peel off the white plastic and stick it on a like a giant band-aid. It helps protect the bonnet paint from engine heat and keeps noise down.
Many years ago I changed my driving style to cope with rising fuel prices; I have now reached the stage where I am contemplating keeping my eyes shut in order to lower wind resistance.
Nice camber in that last pic!!
Remove it!!
Metallic 6 cylinder 5 series sometimes seem to burn their bonnet paint if the foam stuff is missing
