May 19, 2008 19:35:52 GMT
Sorry the image is blurry, but You can see the head of the bolt there, its been scraped along the road a few too many times now, and the head has become a bit thin, Ive bought a new bolt but I'm in a bit of a quandary as to how I get this one out, because of the radius on the ring part of a spanner (or socket), I cant actually get any purchase on whats left of the bolt, its torqued up quite tight (well, it should be). The only thing I can think of is to shave a spanner down so it grips as well as it possibly can, then weld it on to the bolthead, but if I still cant get it out, its going to mean I have to drive about with a 17mm spanner welded to the bottom of the car. The bolt is about 140mm long, and holds the front suspesion on. Any better ideas than mine? I'm open to any help or suggestions I can get, ta in advance!
Last Edit: May 19, 2008 19:37:22 GMT by shedspeed
"Chasin' the gash, with a four-out-the-dash"
May 19, 2008 19:42:04 GMT
Weld a nut on to the bolt head?
... the only injury I sustained was a bumped head when I let the seatbelt of without realizing the car was upside down and that's not really the car's fault.
May 19, 2008 19:45:10 GMT
I had considered that, but Id have thought it'd be tricky to get a decent weld inside a nut to hold bearing in mind how tight it is, although, i guess, if i did it with a big enough nut (22mm maybe)the hole would be big enough to get a decent weld in it..
I might try that first, before sacrificing a spanner. (ta)
stinkwheel
Doctor Of Gonzo Journalism - One of gods own proptypes, never even considered for mass production.
May 19, 2008 19:45:20 GMT
Thats what i said too
1973 Citroen Dyane 6 1980 Citroen Acadiane 1992 Citroen AX 1990 Citroen BX 1997 Citroen XM 1993 Citroen BX 1997 Citroen Xantia 1977 Citroen Ami 8 1996 Ford Escort 1989 Citroen BX 1997 Suzuki RF900 1988 Yamaha TDR250 1979 Honda CB400. 'I need less vehicles'
starionturbo
Is planning mental turbo action MU HUH HUH!!!
May 19, 2008 19:48:12 GMT
Drill it out carefully so as not to damage the thread too much. Then clean the thread up and just re thread the hole if you make a balls up of it.
Skid pan springs to mind................
May 19, 2008 19:48:13 GMT
take the chrome off a knackered socket weld that to it then biiiig breaker bar or a nut gun
Last Edit: May 19, 2008 19:50:18 GMT by hairnet
2001 HONDA CT110 (NOT RCV)
rtlkyuubi
Low and Slow
May 19, 2008 19:49:58 GMT
bit o/t but to all the people with really low cars (4 finger crew) how the hell do you get over speedbumps, ect.
Ryan.
May 19, 2008 19:55:54 GMT
I get over speedbumps like this. *shrug*, worn holes in both front shocks, exhaust is flat at the bottom, both spring cans are much the same, but, at the end of the day, it looks cool as heck!
Last Edit: May 19, 2008 19:57:12 GMT by shedspeed
May 19, 2008 20:02:40 GMT
I don't do speed bumps in 'low mode'. In fact I don't do cats eyes really.
May 19, 2008 20:08:12 GMT
Removal off stubborn and rounded screws are usually carried out in four easy steps.
1. Round the bolt head even more using lots of penetrating oil and that rusted pair of universal pliers that the last owner left in the engine bay.
2. Weld something to it, have the weld break about 4 times before starting to curse the day you bought the cheapest flux core welder you found.
3. Grind the dissfigured metal object that once was a bolt head and drill a hole in it for the screw extractor worth more than the car. Snap the screw extractor. Cry.
4. Drill out the bolt. Depending on the situation you may or may not have to replace most parts in a 10" radious from the bolt. With a huge amount of luck you might get away with retreading the hole.
Good luck!
May 19, 2008 20:27:33 GMT
bit o/t but to all the people with really low cars (4 finger crew) how the hell do you get over speedbumps, ect. Ryan. I don't. i find the "reverse - find another route" trick to be the best way
Your car is not 'epic', this thread is not 'epic'....the OCEAN is epic, the UNIVERSE is epic.... please stop misusing this word!! It would appear Hotrods are the new VWs - aint fashion funny! '69 BUICK LESABRE 350
May 19, 2008 20:29:53 GMT
bit o/t but to all the people with really low cars (4 finger crew) how the hell do you get over speedbumps, ect. Ryan. I don't man ! In fact- that applies to pretty much every car I own, there is a route out of my estate that allows ONE speedhump to be passed, its rather worn down now. ;D
slater
Club RR Member Number: 78
May 19, 2008 20:33:39 GMT
If your slammed motor wont go over speed bumps you aint doing it right! ive never had a problem, just drive and scrape! ;D
May 19, 2008 20:37:13 GMT
If your slammed motor wont go over speed bumps you aint doing it right! ive never had a problem, just drive and scrape! ;D Mine can get over - at an angle - but still scrapes. The new chin spoiler makes it a tad harder now too though Id rather not risk it too much though so avoid the challenge
May 19, 2008 20:38:12 GMT
I find going at an angle helps. Or just clench yer buttocks and hope nothing pings off. ;D Oh and I'd weld a big nut on. And fit some sort of guard for future avoidance. Kudos for the damage
May 19, 2008 20:40:22 GMT
Amen to that! My drive has a speedbump at the end of it, hit it every day, you get used to it after a while, Once Ive changed the axle bolts pictured above, Ill weld a bit of 16mm round bar between them, that'll take the majority of the impacts, and the bolts will be safe, I'm expecting more parts to break, but I'd rather that than drive around in something that looks like a range rover! Edit: if there's Kudos for slam damage, heres the silencer box from the 2cv, it should be round:
Last Edit: May 19, 2008 20:42:18 GMT by shedspeed
May 19, 2008 21:03:20 GMT
Good grief. Think I'll stick with mine looking like Bambi then! I do think this speed hump scraping is a bit silly but then a thought has just occurred to me - you're damaging speed humps. Speed humps are bad and deserve to be damaged. Excellent.
1986 Citroen 2CV Dolly Other things. Check out my Blog for the latest! www.hubnut.org
May 19, 2008 21:08:09 GMT
Theres nowt cooler than leaving a rooster tail of sparks behind you. Its horses for courses really Ian, I do love thrashing standard ones across muddy tracks and feilds etc, but I have one practical family vertigo wagon, so I don't mind having this one a bit lower and IMO a bit better looking!
stinkwheel
May 19, 2008 21:13:45 GMT
Thats why I have these knee sliders.........
Last Edit: May 19, 2008 21:17:12 GMT by stinkwheel
stinkwheel
May 19, 2008 21:18:02 GMT
Last Edit: May 19, 2008 21:25:26 GMT by stinkwheel
