HUUGE negative camber - how?BenzBoy
@benzboy
Club Retro Rides Member 7
May 13, 2005 10:04:56 GMT
How do you get masses of negative camber like the Bosozoku guys do? I've seen it on Beetles too.... Is it just a case of whacking max camber on a stock suspension set-up? I can't see that manufacturers would give the option to use that much camber - is there some customising of the suspension geometry needed?
May 13, 2005 10:24:40 GMT
Bug wheels tilt when you slam them...Just depends on the suspension, both the initial design and geometry.
*n
May 13, 2005 10:28:13 GMT
If you've got struts at the front, elongate the mounting holes in the strut towers. Doing the rear is not so easy. If you've got a solid rear axle, it won't happen of course.
Peugeot 307sw - Suzuki SV650S - MX5.
May 13, 2005 10:28:17 GMT
the aircooled vw's suspension naturally gives negative camber (if its a swing axle style) when lowered. You will see this on early bugs and bus's particularly.
It would need to be dialled in for other vehicles, if memory serves me right this was covered in a 'how to' in custom car last month (maybe the month before) It wasnt solely on negative camber, but suspension specifics were covered in quite some detail.
May 13, 2005 11:26:33 GMT
If you have too much negative camber, especially with wide wheels, you’ll have a tiny tyre footprint => sh1te handling and ridiculous tyre wear. See barried-up Sierras with their semi-trailing arm rear setup for further info.
1972 Fiat 130 1985 Talbot Alpine 1974 Lancia Beta Saloon 1975 + 1986 Mazda 929 Koop + Wagon 1982 Fiat Argenta 2.0 iniezione elettronica 1977 Toyota Carina TA14 BEST CAR EVER!!!!!!!! 1979 Datsun B310 Sunny 4-dr 1984 Audi 200 Quattro Turbo 1983 Honda Accord 1.6 DX GONE1989 Alfa 75 2.0 TS Mr T says: TREAT YO MOTHER RIGHT!
May 13, 2005 12:08:52 GMT
Know what you mean....both of my Sierras have loads of negative camber at the rear with only a 40mm drop!
Anyone know how to rectify it?
My fleet: Suzuki GSX-R600Y SRAD with bald, melted tyres A borrowed Mondeo
MWF
May 13, 2005 12:19:13 GMT
You can get shims for the back of a Sierra but I like a bit of neg camber.
@benzboy
May 13, 2005 12:41:19 GMT
Cheers guys. The Merc has eccentric bolts on the lower wishbones at the front, but even at maximum adjustment there's no way it'd kick the wheels out that far. Not even looked at the back yet but I think with it being semi-trailing arms there isn't gonna be any change in the camber when I lower it. Good call about the front struts Wagoneer... I'll remember that for future ref!!
May 13, 2005 15:58:28 GMT
Imps tend to have camber as well, although they do that as standard, it's not a case of them having camber added later. Some unmodified MkI Imps I've seen have amazing camber at the front when they're stationery. Probably something to do with having swing axles at the front. I think later models were slightly modified to get rid of some of it.
"He's not the messiah, he's a very naughty boy!"
May 13, 2005 21:17:01 GMT
If you have too much negative camber, especially with wide wheels, you’ll have a tiny tyre footprint => sh1te handling and ridiculous tyre wear. See barried-up Sierras with their semi-trailing arm rear setup for further info. the truth hath been spoken ;D when ive got my pentas on the merc, the factory camber runs the insides to wire in under 6 months ;D
street
6.2 ft/lbs of talk
May 13, 2005 22:25:35 GMT
Thats dead weird, i was thinking about how to run oodles of negative camber just yeasterday, so had a look into it and found these on ebay for the escy: adjustable track control arms ;D ;D ;D bidded for them and won!!! Well chuffed! Negative camber ahoy! The rear wont be so easy but i reckon its possible by re-drilling the pivot points have to have a look. Yours looked like it could be adjustable via the eccentric bolts when we were last under it, but like wagoneer was saying it might be possile to move the mounting holes?
All I say is this ,....
mercmad
Flush Hard,it's a long way to McDonalds.
Is that a Hino? early "contessa " maybe?, is the owner a Samoan Sumo wrestler? or is that the factory suspension seeing as it's a "GT". ;D ;D ;D ;D ;D
Many years ago I changed my driving style to cope with rising fuel prices; I have now reached the stage where I am contemplating keeping my eyes shut in order to lower wind resistance.
mercmad
Hally plottasan?
Ed
swing axle - 2 notches at ze back....people think its broken ;D
May 16, 2005 14:59:43 GMT
oooh nice. plebs, thats far from broken ;D
May 16, 2005 15:49:05 GMT
May 16, 2005 15:58:29 GMT
May 16, 2005 16:18:18 GMT
If that Carol is the one I think it is, it has little blue and white kart seats and zero extraneous trim.
*n
Panda Matt
Datsun Owners Club Wannabe
May 16, 2005 17:26:57 GMT
Are those motorbike tyres on the carol?
