I'm hoping to make an air intake to bolt onto the weber carb on my audi from stainless steel to house the LPG mixer. The pancake airflilter jobbie thats on now works great but id like something a bit prettier.
Ive sorted a few household utensils that are made of stainless steel that look to have the right shape and profile and with a bit of cutting, drilling and grinding they will hopefully be transformed into an air intake/plenum chamber. All these bits will require welding together though...
The various containers are made from pretty thin stainless steel. I know ill need to use stainless wire in my MIG but its a gassless one, is gassless stainless steel wire available? Does stainless steel need to be thick to be welded?
Any advice is really appreciated!
purplevanman
Way too orangey for crows
my guess is not with gasless, ideal is neat argon, I have used argo shield but it's not perfect. better to find someone with a TIG
Might be worth a try with the wire you have, pots and pans are pretty low grade stainless (magnets stick to them, its mostly iron) so have a go on a spare bit and see if it works. Thats what I'd do, anyway. I've never used gasless, but have welded ferric stainless with ordinary mig wire. Proper, amphotetic stainless steel, tig welder time
purplevanman
normal wire will weld stainless, but welds will rust
bbq
Though you had a TIG?
Stainless wire and Argon gas if you're using a MIG.
2003 Suzuki Wagon R+. Feel the POWAAARRRR!!! 1968 Volvo 142. My street/strip car. Currently fubarred, it will run one day. 1971 Volvo 142. Parts car. Stripped and gone. 1993 Nissan Sunny diesel. Runs on cooking oil! [/UR
Nope, I don't have a TIG! Never even used one I'm afraid....
I guess I could use normal wire to weld it but id rather it didnt go rusty as id like to polish it up and brighten up the engine bay. Rusty welds would look naff!
Perhaps I should cut all the bits to shape and find someone locally who can weld it for me.
most enginering companys would do it if you tacked it togeather for them, i would do it for ya mate but you live abit far away
I doubt it would cost much to post!
Hi, If your really stuck send it to me and Ill have a go with me tig for ya!
If I had two brains I,d still be a halfwit 1969 Morris Minor Traveller
Where abouts are you? I may take you up on it.
Jun 10, 2008 10:13:12 GMT
And I'm in Fareham,Hants
