Jun 16, 2008 12:45:46 GMT
I'm gonna plonk the battery in the boot on my RX3 - what size cable?...in mm..or in strand size/numbers.
I need about 4 metres.
Can i just run an earth strap from battery to boot floor? Then run one at front from engine to chassis...
wheres some nice/cheap cable...?
thank you muchly alex
Jun 16, 2008 12:53:01 GMT
I'm gonna plonk the battery in the boot on my RX3 - what size cable?...in mm..or in strand size/numbers. I need about 4 metres. Can I just run an earth strap from battery to boot floor? Then run one at front from engine to chassis... wheres some nice/cheap cable...? thank you muchly alex Go for the biggest/thickest cable you can find/afford - its amazing how much current drop you get. With the earth strap - just fix it to the boot floor with a good clean mounting. Not sure where's best for cable - when my mate wired up my car he used cable from a forklift ('cos he was working as a forklift engineer at the time! ) ;D
Old Fords never die they just go sideways
klunk
1949 Rover P3 V8
Jun 16, 2008 12:58:51 GMT
If you know anyone who works for a Forklift truck company get some of their cable, nice and big and minimum drop over the length.
That's what I used, (battery under back seat.)
sooty
Jun 16, 2008 12:59:42 GMT
Is it to save space up front ot try to and get more weight to the back?
The cable is bloody heavy if you use the right stuff.
2016 Dodge Charger Scat Pack 2008 Jeep Liberty Limited
rtlkyuubi
Low and Slow
Jun 16, 2008 13:11:10 GMT
Ive used curse word thin amp cable (as it was already installed in the car ) and its fine so far.
jamesp
Jun 16, 2008 13:17:24 GMT
go buy sme good quality jump leads I found a set n a scrap car so cut em down the wire is nice and thick and as you said earthing it to the boot floor and and engine earth is all you need
Last Edit: Jun 16, 2008 13:18:18 GMT by jamesp
Jun 16, 2008 13:32:22 GMT
I stripped out a copper battery cable from a Rover P6. Plenty thick enough and already has the termial end on it. ;D
BMW e34's have a rear mounted battery if you wanna go the scrap-sourced route.
Jun 16, 2008 13:44:46 GMT
minis have rear batteries
rob0r
East of England
Club RR Member Number: 104
Jun 16, 2008 13:52:39 GMT
Bodieandoyle rescued me a rear mounted battery cable out of a BMW E36, not sure what model but it also has a lovely terminal point box to mount in the engine bay.
E30 320i 3.5 - E23 730 - E3 3.0si - E21 316 M42 - E32 750i ETC
Jun 16, 2008 14:14:28 GMT
We purchase our wire at the welding shop. It's realtively inexpensive and it's super flexible, unlike the automotive wire which can tend to be stiff and hard to run in tight areas.
We run 2 gauge wire as a standard for a rear mount battery here in the US.
andyj
Jun 16, 2008 14:39:06 GMT
Use 16mm2 minimum, the silicone coated stuff is best at the PVC coated cable is not that flexible.
Yes that is me with roy walker in my avatar, TOUCH ME!!
Jun 16, 2008 16:52:34 GMT
wow- great replys....looking in yellowpages as i type(I'm gifted like that) for local forklift companys...and welding companys....and scrap yards.
Next question is...
Who runs circut breakers at the batt end?...in case the worst happens and the wires insulation rubs through! And if you do- what make, kind, where from?
I go home now to play cars, no nerdnet at home...check tommorrow thanks alex
Jun 16, 2008 16:54:52 GMT
jumplead, thats whats on the moggie
slater
Club RR Member Number: 78
Jun 16, 2008 17:09:47 GMT
I don't run fuses on mine.. Ive never seen a car with a battery in boot as standard with a fuse
Jun 16, 2008 17:32:35 GMT
I'll go with the welding lead. Most people I've seen do it use that because of the added flexibility.
Jun 16, 2008 17:59:16 GMT
Yeah, the lead I have isn't very flexible at all. I may keep an eye out for something better.
bortaf
Jun 16, 2008 20:51:29 GMT
Depens on how big the engine is? minis will use less to turn over (hense it has a smaller battery) anything like a pinto i use the cable off vans with tail lifs from the scrappys you can get 2 cars worth from a LWB van
R.I.P photobucket
Jun 16, 2008 21:22:48 GMT
I've got 4m of 10mm core wire with a 2mm coating ready to go on when I convert to a rear mounted battery (I even have the box and fittings.... what am I hanging around for? ). My dad gets it for free from the network technicians who work with him ;D
