Jun 19, 2008 10:43:59 GMT
got into CAD work at uni, learnt a few things did a few assignments.......then got a few bits of pretty CAD hardware, (22" CRT, trackball mouse) and Catia (the CAD package) and started doing a few bits, with the intention of adding it to a portfolio to use for work placement. but after a while i ended up designing things for the sake of designing them, first off were these: which i'm planning on redesigning into a set of twin slide TB's instead of roller barrel as its a better design then i did these: which are going to be built once i've got the escort out the way. theres been loads of bits in between that aren't too interesting........ i was seeing if anyone else has done or is into anything similar?
Stu_B
Investing in rust!
Jun 19, 2008 10:58:37 GMT
About as technical as I get I use it at work with OS maps for designing roadlines & a piggyback package for designing roadsigns. I did some 3d stuff at college with Pro-Eng & Inventor.
rysz
Jun 19, 2008 11:12:00 GMT
I have done plenty of 2D work and would love to get into 3D but finding the time now I am not in Engineering is a bit tricky!
What experience have people had with Solidworks?
Rysz.
markbognor
Club RR Member Number: 56
CAD work.....few bitsmarkbognor
@markbognor
Club Retro Rides Member 56
Jun 19, 2008 11:50:02 GMT
Here's some 3D stuff i've done with Pro-Desktop (A stripped down educational version of Pro-Engineer). Mardave V12 (see the RC Banger thread) Lego Man Lego Shock The majority of what I do is in 2D, vector drawings for plot paths and printing, cutting and etching on the laser cutter or cutting stickers, or just printing nets or orthograpic and isometric drawings, all pretty basic mind as most of what i do is for teaching aids and examples for secondary school kids. Van Net for Year 7 Graphics Laser Cutter plot path, red cut, black etch for a 1/25 lowrider chassis.
Jun 19, 2008 12:19:57 GMT
Jun 19, 2008 12:29:54 GMT
i specialise in catia.......but my uni is too cheap to afford it so next year we use pro E, hpoefully i'll try and keep doing as much as possible in Catia though and i'll be working for primary designs next year who use solid edge and solid works so i'll have to start picking that up soon. and i've done a part time course in 3D studio max for curse word and giggles ;D
Jun 19, 2008 12:50:17 GMT
Jun 19, 2008 16:54:41 GMT
Good stuff.
Solid works, Solid edge, micro-station and the other mid-range 3D systems are good enough for most uses. If you need to design a whole plane, car, factory etc. Catia V5 is the BOY. I-Deas is pretty capable, but not as intuitive.
What you find is that most CAD systems look much the same until you try to use it to manage the data, and have several people working on it, or until you try to do some complex shapes which must be exactly right - things like vehicle panels. Nightmare.
Jun 20, 2008 10:47:28 GMT
Some good stuff there, I've been a CAD monkey for a while and been messing around with 3D programs and computer games like Unreal Tournament and Half life etc, for over 10 years now. Might be able to get a copy of SolidWorks, would love to get stuck into some real engineering type 3d programs rather than AutoCAD and 3Ds Max. I'm mostly doing visualisations in 3DS Max for a civil engineering company, but here's some of my past playing around in autoCAD. Centre caps for my alloys, at the engineers as we speak, waiting on metal! Obligatory BBS Some other random wheels too Some Stuff from work Cant find any of my other stuff, been into caricature animation at the moment. I can pretty much draw anything if I put my mind to it. It keeps me busy I suppose too, would rather be getting my hands dirty on my VW Golf but meh, needs must and all that.
Jun 20, 2008 11:16:15 GMT
I used to sit in front of a big screen back when I had a proper job. Now I just do the odd bit at home. Oxford/MGb front suspension and something work/watch related.
Jun 20, 2008 12:47:48 GMT
Afraid I don't have any of my recent projects, but heres a couple of oldies.
Remade In Australia thereimaginarium.com.au
Jun 20, 2008 13:50:29 GMT
i used prodesktop at school but at uni we use rhino, its a pain in the gooch but it makes lovely renderings when teamed with flamingo or 3dsmax
Jun 20, 2008 13:52:45 GMT
Jun 20, 2008 15:55:00 GMT
Can anyone recommend a good CAD programme for an absolute beginner?
Nathan
Club RR Member Number: 1
CAD work.....few bitsNathan
@bgtmidget7476
Club Retro Rides Member 1
Jun 20, 2008 16:05:06 GMT
I see where your comming from, I studied 3D animation at uni and spent all that time designing my Midget and how it would look. (apart from it not being to scale).
Jun 20, 2008 19:13:54 GMT
Can anyone recommend a good CAD programme for an absolute beginner? What do you want to do with it? That will help pin point what program you need. For example, Rhino is quite easy to learn without tuition & excellent at surface modelling (unless you're doing car bodywork to professional level, in which case you need Alias) but not so good for things like furniture or mechanical design. However Solidworks (amongst others) whilst quite tricky to learn if teaching yourself, is excellent for furniture & mechanical stuff but not so good for surfaces. I can't post up any of my work stuff (I currently use Solidworks to designing the interiors of disgustingly large yachts), but here's a few of my own, from when I was at uni: Rhino, rendered in Bryce. I also have a 1:18 scale model of the sailing yacht, as that was my uni final year project. Rhino, rendered in Rhino
Jun 20, 2008 19:46:22 GMT
Can anyone recommend a good CAD programme for an absolute beginner? What do you want to do with it? That will help pin point what program you need. For example, Rhino is quite easy to learn without tuition & excellent at surface modelling (unless you're doing car bodywork to professional level, in which case you need Alias) but not so good for things like furniture or mechanical design. However Solidworks (amongst others) whilst quite tricky to learn if teaching yourself, is excellent for furniture & mechanical stuff but not so good for surfaces. My boss has been trying to encourage me to learn CAD for years and I've managed to resist* so far...... However, I've got 30 years until I can retire so I guess I must move with the times, I'll give Rhino a go. Thanks for the advice. *Can't learn, Won't learn.
Last Edit: Jun 20, 2008 19:47:52 GMT by skinley
Jun 21, 2008 11:15:54 GMT
i recomend Catia all the time every time, if your going to learn one you may aswell learn the best.
3DS max if you want less technical stuff
Jun 22, 2008 12:11:11 GMT
Anyone know where I can find some good tuition manuals or projects for autocad or pro/engineer wildfire (online or textbooks)? We've been studying it at uni (just finished 1st year mech eng) but we go so slow its ridiculous.
Jun 22, 2008 14:23:15 GMT
used to use a bit of proDesktop at school on my engineering course but the school computers were gay so it made it awkward to use. Used 2d design for a while as well. Shall have to try and get into doing it all again as it'll be useful for future jobs etc
