PhoenixCapri
West Midlands
Club RR Member Number: 91
Awesome idea ;D I've got myself a set of FRZ1000 carbs to do the same thing with on my e-type rep (just need some more now) so I'd love some pics and info on how you're doing the linkage etc. - saves me thinking about it! Keep up the coolness
Colonelk
Club RR Member Number: 83
I'm quite lucky with these carbs in so much as its all built in to the design. You have the two 'terminal' carbs, one with a TPS on, one with the connection for a throttle cable and a bracket to attach the cable to, all built into it, all the carbs in the middle just daisy chain together (you have to set them up so they all open evenly apparently) Is that what you meant? So for the throttle I just need to connect a suitable length throttle cable. Tell me if Ive misunderstood I have to say, now Ive done more research apparently eh 1000cc GXSR's had the same carbs (different jets) but with wider spacing! Shame I couldnt of found some of those really!
rtlkyuubi
Low and Slow
with the bike carbs ive had, they all have little adjusters inbetween each carb to balance them, but ive never had to adjust them, but you might have to as youve mixed 2 sets together.
bring the manifold and carbs down the mora, ive already got the tig out, i may aswell put it to good use
bstardchild
Club RR Member Number: 71
So for the throttle I just need to connect a suitable length throttle cable. Carlton/Senator 2.6 will provide one for the correct fitting throttle pedal end thats also long enough to reach the carbs - carb end might need different approach Big trouble with bike carbs is they are used with bike twistgrips and they are normally short cable travel and not long travel like car ones
Colonelk
ah I see! Well, ill just have to cross that bridge when I come to it. 2.6 cable is a good shout though ruishy.... was going to be down next playday? thats right isnt it? or do you not mean mora by tomorrow? haha ryan.... aye thats how these are, and as pointed out theyve been mixed up, its not hard to get the all the same (allegedly) again.
tomorrow you sarcastic fool
Colonelk
I'm easily confused! and still am! erm
Steve
I'm easily confused! and still am! erm Let me translate it for you : Get ur down A52 tomorrow and you could drive back with a manifold modded for your lovely carbs ;D Simples
so simple even steve got it
Colonelk
haha, you know me, not the sharpest tool in the box! Will have to see if I can jig some things around and come down. I only have the bananananananas, not extra pipe to chop up! THESE (stolen from BC) I havent chopped my up yet though! and a total of 12cm port spacing to make up! (carbs are 6cm apart, car ports are 8cm)
Last Edit: Feb 5, 2011 21:11:53 GMT by Colonelk
easy done, cut the webbing in between each runner and move them where they need to be
Colonelk
don't think I'm going to be able to come tomorrow actually. Was looking at what I needed to get done, but theres a fair chunk! Nevermind, I shall return for A52-ing
Steve
As Ross said, those banananananaas will work fine with the webs cut out so simple even steve got it Simple is as simple does ;D
Love the sound of the Senatron anyway, the bike carbs are going to make it sound insane! Proper awesome. Will be interesting to see what performance increase you gain.
Last Edit: Feb 6, 2011 13:03:18 GMT by Robinxr4i
Colonelk
Feb 17, 2011 17:59:10 GMT
Indeed mate. Ill be happy if I'm level on power or upwards TBH Right, been doing lots of little jobs to the senator as I need it MOT'd asap. Gave it wash (!) as it was starting to look like a garden ornament which is never good. Anyhoo, as the light was fading, I wanted to see where the rear arch line fell with the lotus kit, so I got some tape and shonkily put it in place. Id forgotted how big these kits actually are! /\ the standard side skirts come straight down from the bottom of the door.... these stick out (and down!) considerably further.... should mean itll start to look as low as it actually is! haha /\ That all important archline.... happily it means I can cut out the rotten (and unavailable) rear arches and remake them to suit the kit. Awesomes Going to need every inch of the planned Omega rear subframe and spacers to get the wheels where I want them! I know its not the greatest condition kit, but then I paid buttons for it, and its likely to be smashed to smithereens on track anyhoo so never mind I like the (various) people who have suggested smoothing out what I have, taking molds from them, and then when the smashy smashy happens I can 'just' make a new bit I'm chuffed with that anyhoo
Feb 17, 2011 19:06:20 GMT
looking' forward to seeing all this come together mate! And lovin' your tape skilllz! ;D
Club RR Member Number: 160
1994 Vaux Senator 24v - moar plansRich
@foxmcintyre
Club Retro Rides Member 160
Feb 17, 2011 19:09:10 GMT
Colon. This is gonna be the most epic thing yet. Almost as good as bike carbs anyway
bstardchild
Feb 17, 2011 19:49:21 GMT
Looks good - you'll be sticking it all on with sikaflex then?
Colonelk
Feb 17, 2011 19:59:31 GMT
Thanks guys. BC.... I have yet to decide on the fixing method!
