Nov 16, 2008 22:43:56 GMT
if you have not guessed were talking lambda sensors. I'm supercharging my mini Which will still have a carb fueling the hole thing. I have been warned that if will need to run on the rich side to avoid melting pistons. I am thinking a lambda sensor would be a good idea. Gauges seem to be around £200 now that's not a lot compaired to another rebuild but there's not enough money left in the pot. Is there a more DIY solution out there?
Thanks
1987 Mini with Suzuki Swift GTI engine 2005 BMW E91 320D Touring
Nov 16, 2008 22:54:18 GMT
If you want to have any kind kind of control over your mixture you'll need a wideband sensor. Innovate do a fairly resonable controler but you'll still be looking at around £200 notes for a complete set up. There used to be a diy wideband controller you could buy in kit form like a megasquirt but i don't think its avaliable any more.
deejay
WELSH DRAGGIN'
Nov 16, 2008 23:14:53 GMT
I happen to have a wideband setup for sale if you're int'rested.
It's a Tech-edge one but i can't remember what model...
Pm sent.
How makes the black box ones with the LEDs running across with the weak one side and rich the other they can't be £200?? Or is that a narrow band set up?
kabman
That's just a narrow band sensor. You can make one yourself using a scrap oxygen sensor and a little LCD display you can buy from Maplins for less than a tenner. But it will only tell you if there is or isn't excess oxygen in the exhaust gas - that is, if the lambda is higher or lower than 1. A wide band sensor will tell you how exactly how much higher or lower than 1 it is.
Pm sent. How makes the black box ones with the LEDs running across with the weak one side and rich the other they can't be £200?? Or is that a narrow band set up? The simple ones are the narrow band kits, but they are essentially useless for tuning a car. Wideband controllers are a lot more complex - Innovate do one and I think it's worth spending the money (£150/200) to get something you can rely on to be giving you correct values. There is a DIY wideband controller kit on the market somewhere, but by the time you've bought the sensor itself (Cheapest I could find one was £65) and spend £50 on the kit, you aren't a world away from just buying an LM-1 kit that you know will Just Work.
ChrisT
Club RR Member Number: 225
Nov 17, 2008 11:43:09 GMT
I happen to have a wideband setup for sale if you're int'rested. It's a Tech-edge one but I can't remember what model... I'm using a Tech-Edge 2J1 controller (bought from Trigger-Wheels)with a Vei Systems AFR gauge on my SX. Quite a cheap set-up but works well - readings were spot on when compared to those taken when it was on a rolling road.
joda
Nov 17, 2008 16:11:14 GMT
WOULD this technology work with a 2 stroke?
eg- tuned vespa engine?
Nov 17, 2008 18:44:54 GMT
WOULD this technology work with a 2 stroke? eg- tuned vespa engine? I wouldn't imagine so - The exhaust of a 2 stroke is so dirty that sensors would be fouled in no time.
Brigsy
Nov 17, 2008 19:00:31 GMT
I use the Innovate lm-1 wideband. Best £200 i ever spent. as everybody else has said, steer clear of the narrowband s***e.
