Nov 23, 2008 22:21:15 GMT
Nov 23, 2008 22:23:31 GMT
It's plums I'm afraid.
Run it on unleaded until you have a problem, then sort the head - A-series unleaded heads are buttons now anyway aren't they?
Nov 23, 2008 22:30:25 GMT
Utter utter wibblepoo.
One of the classic car mags tested these a while back on a car with a B-series engine. It had died from valve-seat recession within 3000 (fairly gentle) miles.
So avoid like the plague. They might get away with selling ti to some car owners (Rover V8 engined cars for example, but if they sell one to someone with old brit Iron then it'll just die).
James
EDIT - the A series will die very quickly on straight unleaded, I'm afraid. Although you might be ok, with all that diesel in your fuel.
Last Edit: Nov 23, 2008 22:31:53 GMT by jrevillug
Nov 23, 2008 22:32:19 GMT
Yep they are cheap, my allegro has an E series engine though! I use castrol valvemaster fuel additive, its meant to be the best stuff to use apparently. Probably cheaper just to let the valve seats erode and whack on a used head every every 5 years or so.
Nov 23, 2008 22:37:33 GMT
Even a pricey engineering shop shouldn't cost more than a couple of hundred sheets to wap some hardened seats in a used head for you surely? I know that's irrelevent if you don't have that much or don't want to spend it on the car mind
Nov 23, 2008 22:52:54 GMT
They do work! I fitted one, along with my electric supercharger, magnetic fuel lines, Powertec valve and 99p Mod chip!
Right then! Ha ha! I'd use lead substitute until I had to take the head off then get valve seats or an unleaded head.
Nov 23, 2008 23:07:35 GMT
Lead pellets introduced into fuel tanks or lines are practically insoluble in petrol, and thus the lead content of the petrol, which results from temporary contact with the pellets is, in effect, nothing.
So it won't do anything.
Nov 23, 2008 23:09:26 GMT
That'd be solder then... Those adverts are so full of Bullplop it's hard to know where to start picking holes
1989 Peugeot 205. You know, the one that was parked in a ditch on the campsite at RRG'17... the glass is always full. but the ratio of air to water may vary.
Nov 23, 2008 23:40:02 GMT
can I add that the tetraethyl lead they put into petrol is totally not the same as (as stated, practically insoluble) metallic lead? Yay for snake oil.. DT, I would have believed you, but everyone KNOWS you need a hydrolysis kit to really make that lot work....lol
My usual solution is... run car on unleaded. if it causes a valve seat problem (not allowed to say recession.....) then have hardened seats fitted. If it doesnt, don't.
LOL - literally.
dubzi
Happiness ain't at the end of the road. Happiness is the road.
indeed, the money you save not using this cack you can put towards getting the heads done properly. I just use straight unleaded. On an older head which has done plenty of miles the exhaust seats will be a bit work-hardened anyway and may survive without problem. The issue comes if you have a nice refurbished head with recut/relapped valve seats. Thats why the PC Austin 1800 burned its valves so quickly, they had lapped the valves to zero to get an accurate "start" reading so they were in soft metal. If they had used a 100,000 mile head untouched then they may have run OK on unleaded for much longer. But no thanks to the snake oil...
