DUE TO SOME NEW DEVELOPMENTS THIS CAR HAS TO BE BROKEN NOW AND I don't WANT ANYBODY SAYING PLEASE don't BREAK IT ETC, ITS STILL AS IS IN THE PICTURES AND SPEC EVERTHING IS THE SAME SO IF YOU WANT ANYTHING PM ME OR MESSAGE ME HERE AND I WILL GIVE YOU A PRICE. I WILL BE PUTTING UP SOME SEPERATE FOR SALE ADS SOON OR MAYBE JUST PRICING THIS ONE
UP FOR OFFERS ON ALL PARTS
BASED IN CAMBRIDGESHIRE
Chassis & suspension -
>Full koni adjustable suspension all round with -25mm springs - £120 posted with adjuster knob
>Every bush on the whole chassis is replaced with a polybush including exhaust mounts - Will come in arms etc don't want to sell seperate so prices depend on what you want
>Complete cosworth 4x4 brake upgrade £220 posted for the front setup including the discs, pads, braided lines etc.
>Cosworth rear disc conversion £150 posted including ALL parts needed
>Wilwood brake biasing valve to adjust front to rear breaking strength - PROV SOLD
>Quick rack steering rack, £50 posted
>B&M short shift lever. £120 posted
>Front & rear upper strut brace front - £40 posted.... Rear - £25 posted
Engine - Massive spec
>+1mm accralite FORGED pistions - 1640cc Not covered many miles but cannot confirm how many
>Fully lightened and balanced crank(and rotating assembly)
> Ap racing paddle clutch
> Shot peened rods
> Uprated headgasket & cambelt recently done along with full service
> Rebuilt around 2000miles ago with new bearings and rings
> Fully ported and polished head, cannot confirm yet if vales are bigger etc but been told its stage 3
> Newman cam with solid lifters and vernier
Will do short block(just the head off) for £500, you know the pistons are more than that on their own!
Long block(With the head, cam etc, complete engine apart from manifolds, turbo etc) for £800
Head with cam, vernier, follows etc, basically complete head £300
> Pro alloy massive radiator £240 posted
> Pro alloy massive twin pass intercooler + fans below - £300 posted
> 2x slimline spal fans
> Fully polished crossover pip with dump valve boss welded on and 5th injector holder also welded on and blended in - £80 posted
> Stage 3(cosworth) t3 turbo, 360 bearing, back cut blades etc etc capable of 26psi - £300 posted with manifold & -31 actuator
> Cosworth yellow injectors - PROV SOLD
> Cosworth fuel pump £ 40 posted
> Dumpvalve - £25 posted
> Standalone engine management(go tech) Will come with all software and a laptop to modify the map yourself if you wish and log what is going on with the engine. PROV SOLD
> FULL stainless 3" system from the turbo back with a 4" out rolled(the only way for an RS) tailpipe - £120 posted
> Everything is either painted, chromed or polished
> Pro alloy oil seperator and breather £80 posted with pipes
> coolant swirl pot £40 posted
> Pro alloy header tank £110 posted
> Full blue samco coolant & boost hoses £180 posted
Interior -
> Usual recaro interior which is MINT + will include special tailored seat cover to keep them that way! £250 for pair of mint front seats, collection only prefferably but will pallet for cost of pallet, usually over £50 PROV SOLD
> Only a couple of tiny cracks in the dash(very rare for a S1) £45 posted
> A pillar gauges pod £25 posted
> Ford racing boost gauge and oil pressure gauge £90 posted for the pair with wiring and piping
> Wide band lambda controller and gauge(LC1 innovate setup) logable with laptop and modifiable. £120 posted with gauge, controller, software, probe and wiring
> RS 4 spoke steering wheel with polished boss £50 posted as a little tatty
> Remote control head unit
> White dials with RS logos light by white LEDs £35 posted fully working
MISC -
> Electric windows
> Tilt and slide sunroof(working and NO leaks)
> FULL closure alarm, windows can be shut on remote and controlls the central locking from the fob, 2 sets of keys with 2 fobs. If i can remove all wiring easily £50 posted TOAD alarm
> Good condition s1 original alloys with 3dr centre caps, all nearly new dunlop sp9000 tyres all round. £140 posted
SHELL NOT!!!! FOR SALE BUT WILL SELL PANELS AND CUT PARTS OUT IF YOU NEED THEM
To see underneath, wheel well, floors and a few other pics please check here -
smg.photobucket.com/albums/v318/tizo/s1%20RST/
> Shot peened rods
Interior -
MISC -
> Electric windows
