Nov 28, 2008 16:56:51 GMT
Does anybody know anything about the hydragas pumps advertised in practical classics for £90?
The pumps ive seen go for £250 odd so I'm not sure this cheap item is worth buying- its got to be curse word at that money, hasnt it?
Kyle67
Nov 28, 2008 17:04:26 GMT
Easy to make yourself TBH, I made mine from a grease gun, metal valve cap and a grease nipple. Less than a tenner.
Nov 28, 2008 21:14:56 GMT
Back in the day we made one from a brake master cylinder. The only thing we had to source specific to hydragas was the nozzle for the end of the pipe. Dial-a-ride-height made easy!
Allegro hydragas pipes were notorious for rusting. We found that Acorn plastic plumbing made an acceptable and rustproof replacement.
"Jeremy Clarkson, a man we motor enthusiasts need on our side like Lewis Hamilton's F1 car needs a towing ball and a Sprite Musketeer" My motor
Nov 28, 2008 22:16:44 GMT
The real ones have a vacuum function to evacuate the system prior to presurizing, it makes a big difference.
Nov 28, 2008 22:17:24 GMT
I've used a grease-gun style one with good effect. Very simple and effective.
1986 Citroen 2CV Dolly Other things. Check out my Blog for the latest! www.hubnut.org
The real ones have a vacuum function to evacuate the system prior to presurizing, it makes a big difference. If you are just adjusting the height you shouldn't need it though, we never did. On the occasions we had to replace pipes we found that with a lot of hard work and getting extremely wet we could assemble the system under water pressure from a hose pipe and then bleed it and replace the fluid successfully. I remember expelling the air from a hydragas cylinder by compressing and releasing it fully submerged in a tank of water. Having the vacuum pump would have made our lives much easier though. Happy days. I will always retain a soft spot for Allegros.
I'm almost certain the £90 ones are a greasegun with a flexi hose and a 'proper' low loss connector on. I made and sold a couple of those a few months ago. The proper connector costs about £35 on its own even if you buy it direct from the manufacturer. The grease-gun type is ideal for doing top-ups but if you need to reflate a car from empty after changing a displacer or something, you'll be pumping away for weeks and weeks with one of those. I have bought a hydraulic hand pump to try and make a better job of it. Alternative if you watch eBay theres always either official BL pumps or the liquid levers equivalent going for £60-120 or so. The bit about having a vacuum facillity is unnecessary, you can manage perfectly well without it.
Nov 30, 2008 15:47:01 GMT
I may give the £90 ones a miss then, I'm going to be replacing pipes e.t.c!
I borrowed a pump from rowley classics and it was a class piece of kit, really nice to use. Ive seen similiar ones on ebay but they sell very quickly, often outside the auction.
rowleyclassics
Rowley Classics and Customs Coombs Rd Halesowen
Nov 30, 2008 22:17:50 GMT
lankytim you are welcome to borrow it as much and as often as you need, no need to buy one
1963 Hilman super minx 1963 Moggy Minor Montego estate HL Morgan kit car and 1 wife 6 kids lots of debts am i happy oh curse word YES
Nov 30, 2008 22:24:34 GMT
I might be sorted with a cheap "proper one" now, thanks for the very kind offer though.
If I'm going to break anybodys stuff it may as well be my own, lol!
