LowStandards
The front shocks are pretty dead on my MX5, so i thought I'd look into a set of coilovers. Damn, they want like £700 for a set. Now, I'm all about getting what ya pay for and all that, but if you look at the shocks, they've got a simple eye on the bottom and will bolt to the original top mount, so could i get 'custom' ones cheaper? FrontsRearsHow do i go about ordering a custom set, I'm thinking shock lengths (i want to lower her, so maybe shorter?) Spring rates etc Any help please...
Tim
i think JohnnyS and Adam have had this done - PM them maybe?
Dec 16, 2008 10:30:02 GMT
For an MX5, really, I would try to buy a set. It handles so well and you don't want to ruining by not matching shocks and springs properly. Sure there must be cheap coilies coming in from japan? If you can stretch to £400, you won't find much if any better than these: cgi.ebay.co.uk/MAZDA-MX5-89-98-GAZ-COIL-OVER-SUSPENSION-KIT_W0QQitemZ310100068813Alternatively go for some good springs and shocks, I've heard good things about KYB shocks and eibach springs.
Last Edit: Dec 16, 2008 10:30:34 GMT by Adam
Dec 16, 2008 11:33:07 GMT
LowStandards
Dec 16, 2008 11:57:35 GMT
Are them coilover kits any good though? I guess they just slip ovcer the shocks? Thing is, like i said, my fronts are pretty knackered so would have to factor the cost of new ones in...
Tim
Dec 16, 2008 12:03:51 GMT
Can you put inserts in?
Dec 16, 2008 12:18:22 GMT
Are them coilover kits any good though? I guess they just slip ovcer the shocks? Thing is, like I said, my fronts are pretty knackered so would have to factor the cost of new ones in... Those coilover things are, well, wibblepoo, and will probably knacker a new pair of shocks in a very short amount of time.
horney™
Dec 16, 2008 12:26:39 GMT
I would say the Gaz kit on MX5 parts site looks the best bet. I've run GAZ setups on my minis in the past and they have always been excellent.
Nick
Odin
Dec 16, 2008 13:20:58 GMT
I'm also interested in the original question of whether custom ones are available. I don't want the DIY ones, I'd just like 'normal' coilies to fit my car because you can't get them off the shelf.
Dec 16, 2008 13:22:43 GMT
I'm also interested in the original question of whether custom ones are available. I don't want the DIY ones, I'd just like 'normal' coilies to fit my car because you can't get them off the shelf. Talk to gaz, they'll make them for any application.
bruisercapri
black and blue and black all over
Dec 16, 2008 23:33:41 GMT
Are them coilover kits any good though? I guess they just slip ovcer the shocks? Thing is, like I said, my fronts are pretty knackered so would have to factor the cost of new ones in... Those coilover things are, well, wibblepoo, and will probably knacker a new pair of shocks in a very short amount of time. although they aren't quite the same as the ones in the ebay ad i've got a set of bilstein front struts with the diy coil-over kits on my capri and so far i have no trouble whatsoever with them and my capri gets driven fairly hard whenever i get a chance(track days etc) ;D
