Mr S
10-4 Good buddy.
Had a quick search and couldn't find the answer, so here goes. When you chop coil springs, what effect does it have on the spring rate? My own logic says that as you are removing metal from the spring, you are lowering the spring rate (making it easier to compress) as there is less material there. However, I've heard it said that it actually *increases* the spring rate - could this be right? If so, why? Later this year, I want to lower the 420SEL, but I want to do it 'stealthily' (20mm or so perhaps) so the Mrs can't really tell, she's totally against the idea! lol Then later, I'll get some smaller spring pads and lower it by about 6mm a time, she won't notice that either! Cheers, Martin
It will stiffen them. Each coil now has to compress more for the amount of travel.
Last Edit: Jan 1, 2009 21:08:18 GMT by Adam
Adam is correct.
Your car is not 'epic', this thread is not 'epic'....the OCEAN is epic, the UNIVERSE is epic.... please stop misusing this word!! It would appear Hotrods are the new VWs - aint fashion funny! '69 BUICK LESABRE 350
I repeat! adam is correct.
From my simple calculations, Halving the length doubles the rate or thereabouts.
don't cut springs, YOU WILL DIE!
The size of the bar the coil is wound from is the relevant point - same bar weight over less coils equals more weight per coi and therefore a stiffer spring.
Leverage variation depending on your suspension design will also effect the spring rate.
dannyb
don't cut springs, YOU WILL DIE! i'm still alive ;D
Odin
Can you 'stealthily' lower with cut springs? Sport bras ahoy in my experience.
Not that they're wrong of course!
Cut springs that is, not sports bras - they're all kinds of wrong.
don't cut springs, YOU WILL DIE! i'm still alive ;D No, your dead, like that bloke out the film "Ghost"
gasserjay
Too bad the people who know it all can't do it all
Just slam it if she's not happy she can walk ;D
1970 LTD country squire 1978 VW Westfalia 1988 VW Westfalia 1973 E100 econoline 1973 E200 econoline 1967 VW Sparkafer 1973 VW GT bug 1965 21 window samba 1961 splitscreen double cab 1975 bay single cab 1956 oval baja 1975 Volvo 242 1993 Volvo 945 d24tic 1985 Transit tipper
OK, hopefully here is the equation I have always used for spring rate. k is the spring rate G is a material constant d is the wire diameter D is the mean coil diameter n is the number of active coils. If you cut coils off a spring the only one of these that changes is the number of coils. It decreases and since it is on the bottom of the fraction that means that your value of k, the spring rate, goes up.
OK, hopefully here is the equation I have always used for spring rate. k is the spring rate G is a material constant d is the wire diameter D is the mean coil diameter n is the number of active coils. If you cut coils off a spring the only one of these that changes is the number of coils. It decreases and since it is on the bottom of the fraction that means that your value of k, the spring rate, goes up. Thankyou Seth - I now have something to quote when people tell me I'm talking rubbish!
tigran
In rust we trust. Amen.
Club RR Member Number: 142
Chopped springstigran
@tigran
Club Retro Rides Member 142
Saying all of the above cut springs are running havoc with my stomach at the mo - bouncing around in the car all day long.
What is the solution to get rid of the bounce - better and shorter dampers i guess? Or harder springs? I know that the bounce is from the dampers not doing their job properly.
rtlkyuubi
Low and Slow
it only gets bouncy once you cut loads off. My micra was bouncey because I kept hitting the bump stops
Last Edit: Jan 2, 2009 7:13:23 GMT by rtlkyuubi
Chopped springsDeleted
@Deleted
Saying all of the above cut springs are running havoc with my stomach at the mo - bouncing around in the car all day long. What is the solution to get rid of the bounce - better and shorter dampers I guess? Or harder springs? I know that the bounce is from the dampers not doing their job properly. drive on flatter roads ;D no you are right it s bouncy because it could do with better springs and shocks its sitting about 5mm from the bump stop a shorter shock would sort the problem . exactly the problem the polo has had really. been running it on cut fronts and the stock shocks for a while but really it needed a shorter shock for it to work properly. people put to much into the you shouldn't cut the springs it dangerous argument but when alls said and done its more to with the job of the damper really if its to long for the cut spring it will bottom out giving a harsh bouncy ride
There is nothing more expensive than a cheap Mercedes
don't cut springs, YOU WILL DIE! I think he was being ironical ... of he was thinking of the children.. OH PLEASE GOD THINK OF THE CHILDREN!!!!
Later this year, I want to lower the 420SEL, but I want to do it 'stealthily' (20mm or so perhaps) so the Mrs can't really tell, she's totally against the idea! lol Then later, I'll get some smaller spring pads and lower it by about 6mm a time, she won't notice that either! Good idea, got hints of these two about it:
I think he was being ironical ... of he was thinking of the children.. OH PLEASE GOD THINK OF THE CHILDREN!!!! The children. Of course, silly me...
Yes I was being ironicalised, although I'm still not convinced on the topic of spring cutting..... it just seems a bit of a bodge to me.
Still, weve been here before... horses for courses and all that!
