v8chevette
PROUD TO BE BEIGE!!
Jan 14, 2009 18:35:04 GMT
I'm about to make some adapters to fit Astra GSI calipers and disks to the front of my Chevette and was thinking I may run a few sets off. So is there any interest out there for some kits? What you will get. Two CNC'd spacers to align the disk. Two Astra GSI disks which will have the center bore enlarged and re-drilled to fit the Chevette hub. Eight high tensile bolts to hold it all together. Calipers are not supplied. Not 100% sure on costs yet but I think I can do them for between £80 and £100 + P&P depending on quantity. I could also supply X-drilled and X-drilled/grooved disks at extra cost Please PM me to register an interest
Last Edit: Jan 22, 2009 21:55:54 GMT by v8chevette
v8chevette
PROUD TO BE BEIGE!!
Jan 16, 2009 17:44:24 GMT
The disks are Brembo and measure 256mm.
The calipers are a direct fit on the Chevette hubs.
I have tried a Caliper on my car and the standard 13" steel wheels wont fit, not sure if 13" alloys will as i don't have any.
You may be able to fit 13" wheel by using spacer but i will have to look in to that if there is interest.
Jan 16, 2009 19:34:20 GMT
you have PM!!! ;D
scott
v8chevette
PROUD TO BE BEIGE!!
Jan 16, 2009 20:00:51 GMT
Replied to
`state
Yorkshire and The Humber
Jan 16, 2009 22:39:30 GMT
I might be intersted in a set of spacers if their at the right price,already got grooved discs left over from my gte so they wont be needed.Pm me with a price when you get chance.Thanks.
Look at all the plastic people who live without a care.Try to sit with me around my table,but never bring a chair.
v8chevette
PROUD TO BE BEIGE!!
Jan 16, 2009 22:48:45 GMT
I might be intersted in a set of spacers if their at the right price,already got grooved discs left over from my gte so they wont be needed.Pm me with a price when you get chance.Thanks. Hi, If the disks you have are standard GTE they will need the center bore increasing and re-drilling to a 92pcd. I can do the machining on your disks and supply a pair of spacers and a set of bolts for £70 + P&P. Regards, Jonathan
Jan 18, 2009 23:58:32 GMT
interest +1 ;D
78 Kadett C 2.0 8 valve turbo, holset, rust&other stuff..
v8chevette
PROUD TO BE BEIGE!!
Jan 22, 2009 21:39:31 GMT
I've made the first kit and made sure everything fits Here's what you get. Two of these spacers. Bored on one side to suit the hub. A flange on the other to locate the disk. A pair of Brembo disks bored out to fit the spacer and re drilled to suit the Chevette/Kadett hub pcd. And eight high tensile bolts. And they all bolt together like this Price will be £120 + P&P I shall get a price for postage tomorrow.
Jan 22, 2009 22:05:58 GMT
OOOOhhhh.
They look nice. I don't think they'll fit the viva though - or they'd be mine.
deejay
WELSH DRAGGIN'
Jan 22, 2009 22:12:23 GMT
You can use calibra turbo calipers and discs too! Calipers bolt on and gives you 290 ish mm of stopage power... You'll need 15s to put them under tho ;D
v8chevette
PROUD TO BE BEIGE!!
You can use calibra turbo calipers and discs too! Calipers bolt on and gives you 290 ish mm of stopage power... You'll need 15s to put them under tho ;D Cheers for that, something to look at in the future
v8chevette
PROUD TO BE BEIGE!!
Jan 23, 2009 18:45:02 GMT
Postage will be £15 for a full kit for UK mainland, price on application for anywhere else
yeha
Jan 26, 2009 23:33:33 GMT
I was the first person to do this conversion in the early 90's for a mates road rally manta. Recommended if you want your Opel to stop.
v8chevette
PROUD TO BE BEIGE!!
I was the first person to do this conversion in the early 90's for a mates road rally manta. Recommended if you want your Opel to stop. Cheers for the recommendation, does the same width spacer fit the Manta?
Jan 27, 2009 10:55:16 GMT
You Can also use Audi Discs without the spacers They still need centre bore enlarging and new pcd drilling but they are the correct offset (Within 0.5mm) 256mm Vented Part number is on the brakes thread on the chevettes site if you want it fella HTH Dom
v8chevette
PROUD TO BE BEIGE!!
Jan 27, 2009 17:13:16 GMT
You Can also use Audi Discs without the spacers They still need centre bore enlarging and new pcd drilling but they are the correct offset (Within 0.5mm) 256mm Vented Part number is on the brakes thread on the chevettes site if you want it fella HTH Dom The Audi disks are 22mm thick where as the Astra ones are 24mm so more compatible with the Astra calipers
`state
Jan 28, 2009 11:58:48 GMT
Plus the audi discs are around £80 for a decent branded set,then you`ve got the machining bill on top so you`d end up paying more than a set of these.
V8chevette-i`ll have a set off you as soon as work picks up,at the mo I'm totally skint.
v8chevette
PROUD TO BE BEIGE!!
I can still make these kits to order £120 + P&P
Just wanted to up this with some positive feedback These kits are great, the brembo discs are beautiful, the spacers are incredibly light, they fit perfectly. You might need to restrict lock a little bit however so the brake flexi connector doesn't touch the spring, but it's a small price to pay imo for such an upgrade .
Last Edit: Aug 8, 2009 21:54:03 GMT by lolface
