RetroMat
Column Shifting!
Jan 15, 2009 22:10:45 GMT
Jan 15, 2009 22:14:54 GMT
i put some in a suzuki jeep mine had tungston bulbs the halogens were alot better
97 volvo 940 turbo wagon 87 fiat strada abarth 78 gs1000 82 katana 1100 84 gsx1100 efe
Jan 15, 2009 22:19:51 GMT
from my knowledge, i think a lot of them have slightly different fittings into/onto the bowls. that's not to say they can't be made to fit though so i've heard if you are that way inclined. i bought a complete set of halogen's for the escort though these were about £50ish iirc but that was everything including plastic bowls, bulbs, wiring loom etc
cam
Jan 15, 2009 22:20:23 GMT
those'll fit. they're just the standard old 'lucas' style sealed beams,. with halogens you may want to run a relay system to make it easier on the switchgear if it doens't already run one. be midful though that most inserts you'll get will have a flat glass which may not be up there in the aesthetics department for what you want.
I converted my CROWN (quad headlight 5-3/4" jobbies) to h4 on low beams and long range driving inserts on the high beams with 100w bulbs and a relay for each lamp. such awesome lights now, much better than any newschool car even!
ezzysi
Jan 15, 2009 22:20:43 GMT
I put some in my mk1 escort, made a massive difference.... don't bother with sealed beams.
1991 Mk2 Golf Gti 8v 2005 Passat tdi (daily) 1971 Mk1 Escort 2004 Touran (her's)
ezzysi
Jan 15, 2009 22:22:48 GMT
loon
Jan 15, 2009 23:11:55 GMT
all you need is the H4 light and bulb it does need to be wired differently so don't just plug it in to the original plug
DON'T use the H1 as the brackets are wrong for this application
L :oN
what the fcuk have you done lately
Jan 15, 2009 23:23:06 GMT
Yep, ditch the sealed beams. There are only two sizes of them, so the mini conversion kit will fit most vans, we have them on the mk1 SWB transit
Yep, ditch the sealed beams. There are only two sizes of them, so the mini conversion kit will fit most vans, we have them on the mk1 SWB transit ;D How times change, we used to uprate to sealed beams in late 60s -70s.. called Bright Eyes cant remember who made them, could have been lucas...god i'm old
"Was today really necessary?"
87 VW GTi ( MOT PASSED 26/04/10)
2003 Honda cb250y Nighthawk
05 Micra Urbis
Sealed beamsChasR
@chasr
Club Retro Rides Member 170
I used to have Sealed beams on the MG Midget I had and some on the MGB. Compared to the Halogens on my other 'B they are OK (Midget's were far worse) but the later MGB is on its original Halogen lamps. With new ones it should improve, leaving me to put on the other items onto my older 'B. In terms of current consumption, they are not all that different from normal headlamps, 10W at most on dipped with no difference between main beam. I am debating on Cibies, in a curved glass for Retroness, but I hear that they are not so hot on dipped but amazing on main, maybe I'm a brand whore. Otherwise I may just go for the Wipac Quads. It's good to see a Cov Uni member on here .
Last Edit: Jan 16, 2009 1:41:23 GMT by ChasR
RetroMat
Column Shifting!
Jan 17, 2009 17:56:46 GMT
cheers for the advise all, i think i will go for the halogen kit next payday. The Toyota has already got relays in the head light circuit.
Jan 17, 2009 18:23:49 GMT
Halogen kits?
Good golly, I ought to send somebody a whole case of halogen sealed beam bulbs, which cost pennies more than incandescent sealed beams, draw the same wattage, and that's that. Job done. Go smoke a pipe and pet the cat.
RetroMat
Column Shifting!
Jan 17, 2009 18:27:38 GMT
such things exist then?
Last Edit: Jan 17, 2009 18:34:49 GMT by RetroMat
Jan 17, 2009 18:33:11 GMT
They do, but only in the states, it seems.
Probably dip the wrong way, too.
