Jez
Jan 29, 2009 14:12:56 GMT
Hey! I thought you guys might like to see my latest project - Papa Burgundy, a 1995 Mercedes-Benz E280 (W124-type). I know 1995 isn't exactly retro, but in my defence it's the last of a model introduced in 1985(ish?) and designed in the late seventies! I've owned the car since late 2007 and used it as my daily driver while my Passat variant was my custom show/weekend toy. Running two cars was getting a bit much though so the Passat is going in to hibernation soon, meaning the Benz can fulfill both roles. Bring on the modding! ;D First of all I fitted a set of clear side repeaters. Not very exciting, I know, but it always bugged me that when Mercedes facelifted the W124, they changed the front indicators from orange to clear, but not the side repeaters. A slight oversight in my eyes! Then I went wild and removed the rear badge ;D An option when new, I disagreed with the original owners' choice to have the badge. And so to the wheels. The standard 15" 8-hole alloys and balloon tyres really weren't doing it for me. Especially as the lacquer on the diamond-cut faces was in a really bad way. I wanted to go for something bigger and wider to achieve a nice euro stance. I'd decided on 17" as an optimum size for looks and to retain a bit more comfort and side-wall than 18" or 19" rims would allow. Brock B1's and RH Cups were originally in mind, but then I found these 'Ankaa' wheels from a newer E-Class fitted the bill at 8.5" wide. I'd always loved the simple design and concave dished spokes, so the deal was done. That's about it for now. Here's some pictures from the trial fitting of the wheels: ;D
Last Edit: Jul 5, 2009 18:24:21 GMT by Jez
1990 VW Golf GTI G60 2014 Skoda Octavia RS
Jan 29, 2009 16:57:12 GMT
ive had a few sets of those ankaas, nice rim,be careful with the wheelstuds though!!
300ce lowrider c220 track car c280 youngtimer S320 ...vip no 4 S430 .. 2 x slk 230 500se , E36 amg E 430 E55 amg Ml 320 C43 amg
Jez
Jan 29, 2009 19:20:34 GMT
Why? Because it's easy to damage the lacquer you mean? I've found that with the original wheels!
Jan 30, 2009 17:33:30 GMT
later e class (w211) where those rims originate have shorter,fatter wheel studs,if you fit those rims with the wheelstuds off your polished 8 holes you will damage your parkbrake shoes, i have in some cases also seen a lot of damaged threads in front hubs,where the longer studs are screwed all the way in until theres no thread left on the bolts!!
Jan 30, 2009 17:39:48 GMT
heres one i made earlier!!.(well about 4 years ago!!) drop me a pm if you need any info mate!
Jez
Ah right, yeah I realised that when I did the first trial fitting! I nipped up the bolts and the wheel could be pulled about 15mm away from the face of the hub. Then I realised the wheels are designed for R14 bolts but my car takes R12. Got the right R14 ball-seat, R12 thread short bolts now pm coming your way!
Ether
Papa needs to get low Looks nice, mate. What tyre size are you planning on?
Jez
Thanks Matt! I've gone for 205/45/17. Stretch was essential to clear wishbones, ARB, shocks, arches... everything really!
That size works out a tad smaller than stock too, which also helps with clearance. And low!
Speaking of low, that will happen some time soon. I've seen a Cobra 60/40mm spring kit on POTN which I like the sound of. I'm going for stance over outright lowness!
Jez
Feb 27, 2009 13:03:16 GMT
Well, I have the wheels on the car now! Sorry the pics aren't up to much. Better ones will follow when I get to grips with my new camera... Jobs to do: Drop Rear spacers Rust spots on door and boot Delete headlamp wipers Euro plate surrounds Relocate front plate lower down Fit bumper in-fill
Feb 27, 2009 13:17:45 GMT
Looks lovely Jez. Just a healthy dose of stick now, and it'll look x10 better w124's are eeeeasy to lower as well
There is nothing more expensive than a cheap Mercedes
Feb 27, 2009 13:19:56 GMT
Looking good, fair bit of stretch on that rubber though! I can't help but think that it needs some other big change, to save it looking like 'just' an old Merc on new rims. Maybe the drop will fix this...
1969 Land Rover Series IIa
1980 MG Midget (bro's)
1981 Land Rover Series III
1981 Mini 'Cooper'
1982 Mini HL
1983 Mini Sprite
1987 Mini Advantage
1994 Mini Sprite auto (oil leak left as standard)
2002 Alfa Romeo 147
Ether
Feb 27, 2009 13:33:31 GMT
G's up, nose down:
Jez
Feb 27, 2009 15:01:55 GMT
Thanks chaps! ;D
Well as Matts chop proves, the drop will be the real difference. Thanks man!
Piffle, everyone says W124's are easy to lower, but I don't have one of those fancy 'thru-the-middle' spring compressors! I think i'll just see if my regular ones will make enough space to chop the springs in-situ.
Bizzareatheist - i know what you mean but hopefully the drop will do the trick. I think moving the front plate will help change things up a bit too, and maybe some all-red rear lights?
tigran
In rust we trust. Amen.
Club RR Member Number: 142
Looks cool already, will look very sweet with a drop.
But leave the rear lights - the smoke n reds are dope as hell.
Colonelk
Club RR Member Number: 83
Feb 28, 2009 14:57:18 GMT
They're nice wheels those! Got some on the Senator...... Plans sound ace too! Hope you can drop it as low as the 'shop.... as that would be AWESOME
Jez
Feb 28, 2009 18:24:46 GMT
Piffle, that interior is crazy, never seen anything like it!!! Mine is cloth so I may consider that interior. Cheers for that! Tigran you reckon keep the rear lights standard? I was thinking the red would go with the euro kinda style I have in mind. Seen them on a few 190's and C's and the look cool. Colonel, cheers! They look ace on the senator, that thing is awesome! I doubt i'll be quite as low as the 'shop as I want to keep it practical for daily (ab)use. We'll see how it goes tho
Jez
Mar 24, 2009 19:02:42 GMT
Colonelk
Mar 24, 2009 19:07:12 GMT
heh thanks man,
and you car is going to look gooooooooooooooooooooooood when its dropped. Cant wait to see the finished result!
llamaboy
I can't believe it's not better.
Mar 24, 2009 19:20:42 GMT
Thats a rather nice motor you got there.
It's gonna look even better dropped. *schemes about lowering my car*
1992 Rover 214i (scrapped)
1995 Rover 214Si (sold)
1975 Rover P6 3500 (scrapped)
1984 Vauxhall Chevette (bangered)
1971 Rover P5b Coupe (sold)
1995 BMW 318i (sold)
2001 Peugeot 206 (sold)
2000 Rover 25 (gave back to father in-law)
1989 Lancia Prisma (swapped)
1985 Volvo 340 (sold)
1997 Daewoo Nexia (hmmm...)
