Jan 31, 2009 19:06:19 GMT
...........do we do this here? hello anyway! got a problem and I thought this place (looks a nice place!) might be able to help!! bought a vw a while back and it came with ford engine fitted? anyway its running a little rough so I wana service it? trouble is I don't know what it is or what its come from to order plugs points etc! ive got all the numbers off the engine and I have a pi too so can you help me please? numbers.......................... 21030 185 (stamped all over!) 35hm6015aa ford 25c80 (with a border all the way round) and thats about it? although I am thinking of selling on and putting a gti lump in there instead? but as funds allow!
Last Edit: Feb 1, 2009 17:49:52 GMT by rowlesy
Jan 31, 2009 19:09:42 GMT
hello and welcome. looks like a pinto to me. theres plenty of ford boys here who can provide more info.
Jan 31, 2009 19:10:39 GMT
cheers mate!
Jan 31, 2009 19:12:06 GMT
its a pinto engine anyway, probaly from a sierra, maybe a cortina if its got points ignition, probably a motorcraft dizzy, should be the same points and plugs across the range. 2.0 or 1.6?
"quote hairnet"
I'm not paying nine pound for a pi$$!
[/quote]
Jan 31, 2009 19:19:34 GMT
deffo a pinto 185? ? could be a rare 1800cc pinto as 2 litre pintos have 200, or 205 stamped on the block anything stamped on the timing belt cover?
Last Edit: Jan 31, 2009 19:21:11 GMT by Autofive
Someone just shot the elephant in the room.
Jan 31, 2009 19:21:53 GMT
will have to have a look!
Jan 31, 2009 19:49:06 GMT
The engine in the photo is deffo a Pinto. If the 185 is on the side of the block then it'll be a 1.8 Edit: Sod sticking a GTi lump in it! Get a 2.0 pinto in there
Last Edit: Jan 31, 2009 19:51:42 GMT by Robinxr4i
philsford
Club RR Member Number: 100
Jan 31, 2009 20:02:27 GMT
The cambelt cover will have an engine size stamped in it.
Jan 31, 2009 20:10:56 GMT
if it has a VV carb, rather than the usual weber 32/36 - this might explain the rough running - as these VV carbs are rubbish
Jan 31, 2009 20:15:37 GMT
isnt the 185 a transit lump low comp i think
97 volvo 940 turbo wagon 87 fiat strada abarth 78 gs1000 82 katana 1100 84 gsx1100 efe
Jan 31, 2009 20:58:55 GMT
185 = 1.8, Rare sadly because they wern't very good Usually came packing a Peirburg! VV was the next best but still pretty bad option! Engine would be a lot better by just sticking a weber on! But if u can get a good 2.0 then do that! For car exact parts u would be looking at Ford Sierra 1.8 83>87 Pinto engine. Most of it would prob be same as 1.6 and 2.0 Pinto's. *edit* infact even a good 1600 would be better! Just seen rest of your photobucket looks like it's already packing a Weber? If so might need a tune up Anyway welcome!
Last Edit: Jan 31, 2009 21:06:42 GMT by Deleted
Jan 31, 2009 21:09:06 GMT
.....or a carb refurb kit
any leaks on the carb?
Jan 31, 2009 21:56:24 GMT
Welcome to RR rowlesy! Not all that clued up on blue oval stuff but it seems like ^^ that lot ^^ have shone some light on it for ya.
Welcome to RR rowlesy! Not all that clued up on blue oval stuff but it seems like ^^ that lot ^^ have shone some light on it for ya. yeah! cheers chaps!
welcome matey. where you from?
might just need a tune up as said but much more potential with a 2.0..... spose it depends on which way you want to go with it & what your funds are? a 2.0 would be a straight swap for starters.
Anyone thinking what I'm thinking? ;D ;D ;D ;D Actually would a Zetec or something slot in there on the Pinto adaptor?
doh! ive got a 2.ol weber on it! prob wont help!
.....or a carb refurb kit any leaks on the carb? If it's a V V carb forget it. Tried to get one last october but no longer made. Luckily I had a scrap one that I got the bits off.
on the block below exhaust manifold will be one of the following
1.6 or 165 = 1600 1.8 or 185 = 1800 2.0 or 200 or 205 = 2000
due to the 185 mentioned earlier i'd say its an 1800 as stated not the best but if not smokey/rattley then prob needs needs a tune, if is knackered then a 2.0 is a straight swap.
theres more to life than mpg & to much power is just enough.
