selling a skoda estelle 120 fitted with a alfa romeo 1.5 boxer engine fitted this car need finishing off change of plans means I wont get around to doing it the car is solid with needing a small patch welding on the one sill this is not a weekends work and drive it as stated it a project intended for road/ track use fancy the challenge
Last Edit: May 23, 2009 5:41:00 GMT by madmods
Filthyjohn
Currently on the road: 1/11
This is a really cool idea! Was the gearbox flipped upside down to make it go forwards? I'd like to see more pics, but probably can't take it on as there's already a queue in my garage. I've often fancied nid-mounting one of those engines in something tiny like an uno or metro mk1.
'95 Volvo 945 Turbo
'87 Volvo 765 TIC
'75 Opel Manta A 2.0 16v,
'86 Volvo 360 turbo,
'62 amazon,
'67 MGB GT.
I think the Alfa engine fits to the existing Skoda gearbox with an adapter plate, so it'll still be rear engined & rear wheel drive. Of course I may be wrong
I think the Alfa engine fits to the existing Skoda gearbox with an adapter plate, so it'll still be rear engined & rear wheel drive. Of course I may be wrong spot on fella
selling a skoda estelle 120 F reg fitted with a alfa romeo 1.5 boxer engine fitted this car need finishing off change of plans means I wont get around to doing it £400.00 REVISED PRICE WITHOUT THE ALL IN THE ORIGINAL ADD car as seen in the picture this is not a weekends work and drive it as stated it a project fancy the challenge LAST CHANCE BEFORE EVILBAY
Last Edit: May 23, 2009 5:33:59 GMT by madmods
BTTT yet another that needs to go will be a great track car for RR 09 with all those tight corners with that flat four sound
May 23, 2009 10:12:08 GMT
this looks like it would be fun, but don't have anywhere to work on it does anyone have a lockup/ space available for rent in ayrshire ? then i would be 99% sure i would buy this
May 23, 2009 10:57:35 GMT
any chance of an engine bay pic? Is everything basically hooked up on the engine front?.....does it run? can u give a bit more detail as I'm very interested in this
May 23, 2009 17:43:25 GMT
This is painful - it looks absolutely brilliant! But I'm still in the process of flat-hunting... and the place I just looked at was pricey but had a garage .... hmm.
May 25, 2009 18:41:01 GMT
any chance of an engine bay pic? Is everything basically hooked up on the engine front?.....does it run? can u give a bit more detail as I'm very interested in this hi sorry for the late reply i have been away at a car show all weekend the engine is all hooked up to the gearbox all wired,it needs a exhaust making & the petrol tank was in the process of been taken out & one going under the bonnet fuel lines have been put in, i had it running last march but not run it since again i carnt get to it as i have car parts all around it i will try & get some engine pictures etc later in the week or weekend hope this helps thank for your intrest
May 31, 2009 16:15:35 GMT
Last Edit: May 31, 2009 16:25:29 GMT by madmods
ruffgeezer
Attracts french tat.
May 31, 2009 20:51:35 GMT
What needs finishing exactly? Does it run? Do you have the bumpers?
What needs finishing exactly? Does it run? Do you have the bumpers? needs the tank moving to the front pipes have been run,last run about this time last year, no bumpers,some welding on the sill,exhaust need making,roll cage needs finishing, again it depends what you are looking for or for what use? track or just road use as i said its not just a weekends work but alot of the hard work has been done ie engine fitted hope this helps thanks for your intrest
The cage appears to be safety devices....what needs finishing on it?
The cage appears to be safety devices....what needs finishing on it? the cage is a safety devices one but not for that car so its been modified to fit but still needs a front cross bar sorting & any oher side bars you may require
