which ones do what? the middle one is the feed to the ECU, i've established that. the only diragram i've got is labelled by colour, and my wires are all beige! one will be the ground and one will be the reference voltage but the million ruppee question is which one is which
sorry, engines a 94 zetec silvertop and that be a throttle position sensor plug.
I'm off back to the yard in a moment, I'll check and report back in an hour. Cant remember off the top of my head, but I do know if you wire it backwards it does no harm but reads very strangely and wont run right
haha, brilliant, even if you could tell me what colour cables goes to what part of the plug, as i've got the rest of what i need to know
from the plug side, oriented as per your pic left to right is earth, signal, power
you're a superstar mate
