RetroMat
Column Shifting!
Aug 21, 2005 20:45:40 GMT
I fitted a radio to the Toledo today, just a simple one with only 2 wires, 1 wire from the ignition which was already in place and an earth to a nice little hole under the dash. Tried it and it works first time, how ever for some strange reason the heater blower and the reverse lights have stopped working all the fuses are fine i can't see any thing wrong so i'm stumped. Any one got any suggestions?
Aug 21, 2005 21:20:30 GMT
"He's not the messiah, he's a very naughty boy!"
Aug 21, 2005 21:56:50 GMT
do they work with the radio disconnected?
Aug 21, 2005 22:49:23 GMT
You need some of that replacement Lucas wiring harness smoke, that'll fix your problem.
RetroMat
Column Shifting!
Aug 22, 2005 12:19:19 GMT
Update: The reverse lights turned them selfs on at about 2am last night, they appear to have self repaired but at least they work now. I can't find any lose wires but i will have a further rummage today. sadly no the heater still doesn't work with the radio connected or disconnected Also today as i was driving along in the rain me wipers stopped working ;D
Aug 22, 2005 12:29:10 GMT
Does the loom run behind the radio you've fitted?
I like long walks, especially when they're taken by people I don't like.
Aug 22, 2005 13:12:40 GMT
Ahh British electrical systems.. they run like clockwork. British clockwork. ;D
Skyline: 1963 - 1973 - 1983 Sunny: 1982 450SLC: 1973 Navara: 1992 Gloria: 1992
Aug 22, 2005 16:59:40 GMT
Mine are always fine and dandy <runs>
RetroMat
Column Shifting!
Aug 22, 2005 17:50:09 GMT
right wipers are now working fine, i replaced the orginal 1972 fuses with some new ones. However still no heater blower sort of, there is one of many bundles of wire behind a card board panel thing
Last Edit: Aug 22, 2005 17:52:03 GMT by RetroMat
Davenger
It's only metal
Club RR Member Number: 140
BL electricsDavenger
@dminifreak
Club Retro Rides Member 140
Aug 22, 2005 23:47:28 GMT
Are there any hidden in line fuses? BL are good at hiding them and not telling anyone. You could always cruise down to Thorrington and let me have a look at it
right wipers are now working fine, i replaced the orginal 1972 fuses with some new ones. However still no heater blower sort of, there is one of many bundles of wire behind a card board panel thing There could be a broken wire in the loom somewhere behind the radio that you've disturbed whilst fidling....?
