horney™
Rear turrets prepared for the harness bar spreader plates: IMG0059.jpg by Nicholas R Horne, on Flickr IMG0060.jpg by Nicholas R Horne, on Flickr Marcus my welder like caged animal: IMG0062.jpg by Nicholas R Horne, on Flickr Fire extinguisher pull fitted: IMG0063.jpg by Nicholas R Horne, on Flickr Pit to car radio antenna installed: IMG0064.jpg by Nicholas R Horne, on Flickr IMG0065.jpg by Nicholas R Horne, on Flickr Harness bar spreader plates welded on: IMG0066.jpg by Nicholas R Horne, on Flickr IMG0067.jpg by Nicholas R Horne, on Flickr IMG0068.jpg by Nicholas R Horne, on Flickr Harness bar ( Proper CDS spec stuff!) fish mouthed and test fitted, had to be put in with a hammer so it's a good tight fit: IMG0069.jpg by Nicholas R Horne, on Flickr IMG0070.jpg by Nicholas R Horne, on Flickr Harness bar welded in: IMG0071.jpg by Nicholas R Horne, on Flickr IMG0072.jpg by Nicholas R Horne, on Flickr IMG0073.jpg by Nicholas R Horne, on Flickr Blown over with primer: IMG0074.jpg by Nicholas R Horne, on Flickr IMG0075.jpg by Nicholas R Horne, on Flickr IMG0076.jpg by Nicholas R Horne, on Flickr There was a hole in the passenger floor where a section had be cut out to access the captive nut for the front subframe by the last owner. THis had never been patched over, it has now!: IMG0080.jpg by Nicholas R Horne, on Flickr IMG0081.jpg by Nicholas R Horne, on Flickr IMA0082.jpg by Nicholas R Horne, on Flickr Roof is a bit warped after the welding and the fact it has no braces, shouldn't be too hard to sort though: IMG0086.jpg by Nicholas R Horne, on Flickr Sharing the workshop with the Poprod: IMG0088.jpg by Nicholas R Horne, on Flickr Nick
bstardchild
Club RR Member Number: 71
Does the bonnet clear both when opened and shut?? Cracking on with it - I've been enjoying the progress The other thing I wodered about was if the harness bar was too low
horney™
Jun 17, 2012 11:03:09 GMT
Fire extinguisher pull fitted: Does the bonnet clear both when opened and shut?? Cracking on with it - I've been enjoying the progress The other thing I wodered about was if the harness bar was too low Good questions. Didn't think about with the switch and pull TBH, could be a skool boy error but they're in the same place as on the original car so hopefully no problem. The harness bar is fine as the buckets sit really low. My mate has the bar in the same place in his MKII and it's well within MSA regs for the angle and safety. Nick
horney™
Jun 17, 2012 11:12:56 GMT
adi
Jun 17, 2012 12:16:49 GMT
Just a thought, if the bonnet does foul the switch and pull, just shorten the bonnet prop! I've had the bonnet open on my mk2 today and tbh looking at the angle the open bonnet sits at, I think you'l be fine.
bstardchild
Jun 17, 2012 20:06:35 GMT
Does the bonnet clear both when opened and shut?? Cracking on with it - I've been enjoying the progress The other thing I wodered about was if the harness bar was too low Good questions. Didn't think about with the switch and pull TBH, could be a skool boy error but they're in the same place as on the original car so hopefully no problem. I fitted one to the Monza and first time I lifted the bonnet with the engine running I sheared the key off and cracked the isolator body...... Ooops lesson learned - you can always fit a plastic packer under the switch body if it's a smidge high The harness bar is fine as the buckets sit really low. My mate has the bar in the same place in his MKII and it's well within MSA regs for the angle and safety. Nick OK - you've got it all covered Great thread BTW - really enjoying the progress
horney™
Jun 18, 2012 18:59:57 GMT
Cheers dude. I was hoping to get it done for the gathering but sadly it's just not going to happen.
Nick
horney™
Been very slack on the updates recently. Progress has been a tad slow due to me being on holiday and also after arrival of the MSA Yearbook it was clear to be sure of passing scrutineering that the cage would have to be fitted with different plates so I had to cut them all out and start again. Due to the above and some scheduling issues at Marcus's workshop it won't be being painted this coming week as was the plan. Hopefully however I can get the shell prep done and it can go in a week later than planned. Anyhoo have some pics: IMAG0092 by Nicholas R Horne, on Flickr IMAG0093 by Nicholas R Horne, on Flickr IMAG0095 by Nicholas R Horne, on Flickr Still needs more weld but getting there! Finished patching the drivers door (passenger door done a while a go): IMAG0098 by Nicholas R Horne, on Flickr IMAG0099 by Nicholas R Horne, on Flickr IMAG0112 by Nicholas R Horne, on Flickr IMAG0111 by Nicholas R Horne, on Flickr Just needs a skim of filler and some tidying up to finish it off. The boot lid I got was indeed much less rusty than y old one. All now stripped down, lightened and de-rusted ready for paint: IMAG0108 by Nicholas R Horne, on Flickr IMAG0110 by Nicholas R Horne, on Flickr Nick
Jul 15, 2012 19:20:12 GMT
is the roof panel just butt welded in? thinking of options as mine is rivetted and a bit shonky.
was thinking maybe joddle the edge then use oversized panel so its flush ?
horney™
Jul 15, 2012 21:44:54 GMT
Yeah just cut to size and spot welded in.
Nick
horney™
horney™
Day 2 Untitled by Nicholas R Horne, on Flickr Untitled by Nicholas R Horne, on Flickr At some point the rear panel had been replaces (badly) and the seams filled. When I ground it all back it was horrid mess, Marcus cut, ground, welded and fabricated new seams. Untitled by Nicholas R Horne, on Flickr Untitled by Nicholas R Horne, on Flickr Untitled by Nicholas R Horne, on Flickr Spot welding sunroof panel Untitled by Nicholas R Horne, on Flickr Untitled by Nicholas R Horne, on Flickr Untitled by Nicholas R Horne, on Flickr Nick
horney™
horney™
Nov 18, 2012 21:40:03 GMT
Another weekend, more progress. underseal removed: Untitled by Nicholas R Horne, on Flickr Roof needed some bracing to stop it flopping about after removal of the sunroof and it's mechanism: Untitled by Nicholas R Horne, on Flickr Spare dash for flocking by The Flock Shop: Untitled by Nicholas R Horne, on Flickr A windscreen to pop in while the clear one I want is on back order: Untitled by Nicholas R Horne, on Flickr Rear strutbrace and badge ready for primer: Untitled by Nicholas R Horne, on Flickr New front valance with some stonechip applied: Untitled by Nicholas R Horne, on Flickr Flatting back first coat of primer on the bonnet: Untitled by Nicholas R Horne, on Flickr A selection of flatted panels awaiting coat 2 of primer: Untitled by Nicholas R Horne, on Flickr Needed to hang the wings somewhere for the primer to dry!: Untitled by Nicholas R Horne, on Flickr Many primered panels! Untitled by Nicholas R Horne, on Flickr That's it for another weekend. Nick
horney™
Dec 22, 2012 22:33:00 GMT
So......er.....yeah. Got fed up of trying to rebuild the roof with filler after warping it. Fibreglass roof panel incoming! Nick
Dec 23, 2012 15:44:43 GMT
That rear strut bar is an abomination of technology.. Constricts movement of the shock absorber top pins, which are meant to be able to move. Why would you refit it? The bar you welded in should do what you actually want it to do (stop the shock towers from moving) just fine.
horney™
Dec 23, 2012 18:00:44 GMT
horney™
Incoming! Nick
awesome project, coming on nicley!
