As seems to be the trend lately, I'm having a clear-out!
BMW e34 TDS Intercooler
Good condition (bit oily!) no leaks. Measures L: 68cm H: 7cm D: 10cm with 52mm diameter in / out pipes.
£10
Ford Escort RS Turbo Intercooler
Great condition, doesn't look like it's had much use. Measures L: 32cm H: 15cm D: 6.5cm with 52mm hose attachments.
£10
Ram-Air performance air filter
Unsure of application - tis brand new, never used. I think Peugeot 106 rings a bell but I intended to use it on something else. Measures L: 18cm Dia: 13cm Inlet pipe dia.: 66mm
£15
K&N Performance air filter
Again, unsure of application (could be Saxo?) but I know for a fact it fits into an MG Montego airbox! So possibly can be used in other BL stuff. Used but in good condition, no crushes or tears. Measures 16.5cm tall and 12.5cm diameter.
£8
1970's Cruise Control kit
Bit of a retro oddity! This was brought over from Canada in the 1970's, and is basically an aftermarket cruise control kit. From reading the instructions this can be fitted to either an auto or a manual! And has a little box of 1970's electronic wizardry to maintain your speed whilst cruising. It's all complete, never fitted.
£25
That's all for now. No doubt I'll come across more stuff whilst sorting the garage out. If you want any of it, either reply on this thread or drop me a PM. I will post, items located in Nottingham if you'd rather pick 'em up.
£10
£10
£15
£8
£25
