Hello,
I bought a new toy the other day.
its a slightly tattier looking one of these...
Will it start? Will it f***.
Its a 3 cylinder Yanmar diesel engine with a wee turbo on it.
The pre-heat works fine, but the engine turns over and over without a hint of firing. But, give it a tiny (less than half a second) puff of coldstart spray in the intake and it fires up first turn and once running, works perfectly. Power is good and it doesnt smoke at all.
Kill the engine and if you restart within a couple of minutes, it will start ok, but any longer and it will need another puff of coldstart to get it going.
preheat definately works.
I havent yet done a compression test, but given how well it does run, I don't suspect anything wrong there.
Perhas worn/dirty injectors? if their spray patern wasnt great would this give these symptoms? I would have thought it would smoke a bit in th case.
Any other suggestions?
Thanks,
Thanks,
