Jun 16, 2009 15:02:48 GMT
what are they like in use-do they work.. My rx3 is 110. Ford are 108. So only 1mm out at each bolt. So thats not much of a differance to take up is it?
Wheels i'm looking at are steel. Are there wobble bolts out there that are threaded all the way?
LowStandards
Jun 16, 2009 15:12:36 GMT
Using them on My 1300 kid, thats 110mm as well, running Ford rims, not a single problem, there very safe! don't be put off by nay-sayers. There just as safe as conventional bolts, hell there exactly the same as normal bolts with the loose washer, but the washer has a slightly bigger hole to allow full location! "Non-Hubcentric" i'll here someone cry, meh, getting your rim 1mm out of centre is still likely less than the factory run-out of steels, plus you think your tyre is actually that round???
Jun 16, 2009 15:14:03 GMT
Jun 16, 2009 16:17:47 GMT
When one thread just isn't enough!
Jun 16, 2009 16:52:32 GMT
darn- i don't know how the hell i did that?... whoops. now going to next post....
