grant
Hi lads, i'm not going to be using this lot anymore so its up for grabs. Xe 67k from cavalier gsi ( not coscast) uprated injectors Manta box with mk2 cortina gearstick welded on so you could put an escort knob on on to be less suspecting Manta sump + pick up pipe gives the correct 7 degree angle the engine should be run at. RWD exhaust manifold Manta engine mounts, these wouldent take much to adapt to fit the escort cross member I wouldent think or purpose made ones are cheap. Manta front propshaft Coil pack so you don't have to modify your bulkhead, comes with all the wiring loom. The rocker cover needs blocked at the end to run this loom. Comes with the inlet manifold to run this loom. Ecu. Also a new radiator that should fit across the inner wings (cant remember the make) or use your own. Only have a pic of the engine for the mo, but the box and sump are very clean. Also RWD Exhaust manifold New radiator Half propshaft Forgot to take pics of those £800
Last Edit: Jun 25, 2009 21:43:39 GMT by grant
haggis
Jun 22, 2009 10:03:53 GMT
if i get a job, ill be in touch!
grant
Jun 22, 2009 12:42:15 GMT
I'm in the same situation, at least its summer lol
Jun 22, 2009 19:03:18 GMT
would you sell without the rwd stuff?
if you cant beat them join them...... Buy a corsa and fit a rather large engine, that soon Pee's the chav's off
grant
Jun 23, 2009 14:01:02 GMT
If i had enough intrest i would, but would prefer to keep everything together.
Jun 23, 2009 15:13:20 GMT
ok Pm me if you are willing to sell the engine seperately, also does it come with alternator, starter motor, wiring loom, ecu and flywheel? thanks
grant
Jun 24, 2009 22:59:47 GMT
Everything is there except the alternator starter and bottom pulley, totally forgot about that lot, havent looked at the engine for ages... I'll knock £200 off for that lot.
So £800 lads, got to be worth that the sumps and boxes go for a fortune alone!!
grant
Jun 25, 2009 22:57:14 GMT
Bump new pics
grant
bumpty bump bump
grant
bump
grant
Jul 13, 2009 14:04:45 GMT
bump offers?
Jul 13, 2009 14:31:40 GMT
It says pethshire in your location, but do you have a posty code i could work out exact distance on?
1987 Opel manta GT 2.0 16v 1976 Opel manta s project 1985 Opel Rekord E 2.2i 1992 Vauxhall Carlton 2.3TD 1989 Mercury Grand Marquis 2005 Landrover discovery 3
grant
Jul 13, 2009 15:46:48 GMT
Hi there, ph13 ;D
Jul 13, 2009 17:30:18 GMT
Ooooooooo 630 mile round trip......
Think i'l pass on that one
Cheers.
grant
Jul 16, 2009 22:57:05 GMT
A friend got to manchester and back by tea time a couple of days ago, but he did leave at 5 in the morning and he was in manchester for 2 hours. I saw your post on the manta owners club about the other one that was in cornwall, your not having much luck!
Anyhow................. Offers before the dreaded ebay??
Jul 17, 2009 14:21:49 GMT
grant
Jul 18, 2009 12:53:31 GMT
That would be good, do you just now need the engine seeing yours is a 1.8...
tctech
Jul 18, 2009 13:25:00 GMT
would you consider putting it all on a pallet if i was to arrange and pay for my own courier not going the offer route just tell us what the bottom line is its easier that way i don't like haggling regards
grant
Jul 18, 2009 13:32:10 GMT
PM'd
deejay
WELSH DRAGGIN'
Jul 18, 2009 19:25:45 GMT
Hey fella, how much for just the sump and box?
