I had these in the Lupo for a bit - Was happy with them, but just fancied a change so took them out. They are a single beam kit, so you only get dip, but its pretty bright, and in the Lupo was plenty - I used to do 15 miles a night on unlit country lanes to and from the ex girlfriends and they were great. Didn't dazzle either in my application They are in the original box, and work perfectly. £40 posted, if not sold prior I'll take them to RRG09 where they can be exchanged for shiny things, lots of beer or some sort of wife.
Last Edit: Aug 6, 2009 20:35:19 GMT by cobblers
don't suppose you have a pic of the kit and the wiring do ya?
don't suppose you have a pic of the kit and the wiring do ya? I didn't, but I have now: The ballasts still have their protective plastic on Basically the bulb bit has 2 spade terminals - these go into the connector that the normal bulb would go to, and take 12v through the grommet (you drill the rear bulb covers for these if present) up to the ballast, which sends many many volts back through the grommet to the HID bulb which clips in the headlamp like a normal bulb would.
festa
Now then pal, £30 collected?
And do you know if they will fit my Mk3 Polo GT?
Now then pal, £30 collected? And do you know if they will fit my Mk3 Polo GT? I'd take £30 collected yeah. If your polo takes H4 bulbs then it would fit - Look on the back of the bulbs, and if they have 3 prongs then they will fit. give me a ring/text on 07595956841
Last Edit: Aug 10, 2009 11:07:09 GMT by cobblers
