Evening guys, simply had enough of the mini and I think its just time to move on after 3 years. Going down the breaking route as its poorly packaged but had plenty of good bits on it...
Flip front - £100
with headlights, grill and lighting loom. Brace bars are welded to the car unfortunately...
Rear Subframe - £150
Not got a pic yet but it was a heritage panel for the MOT 2 years ago which was powdercoated white so it should be in mint condition. radius arms available separately.
Minilites - £30
3 with falkens one summat else, all low but legal tread, wheel nuts included, locking too
Short engine & Gearbox - £120 & £80
looked like this about a year ago. Had new rings and shells and has been maintained since. Not running due to electrical gremlins. Fitted with 276 cam, new followers, double valve springs. Compression test showed al cylinders to be good and identical on compression.
Gearbox was reconditioned by guessworks off tmf at the same time, just needs speedo drive gear, can be kept together on request...
Quick List:
Fuel Tank,
Bootlid,
Rear lights
Adjustable suspension bits - shocks + geometry
Reconned hubs
Switch panel
Column Stalks
Loads of other bits as with any other car for breaking but its surprisingly empty.
thanks,
Sam
Flip front - £100
Minilites - £30
Quick List:
Fuel Tank,
Bootlid,
Rear lights
Reconned hubs
Switch panel
Column Stalks
thanks,
Sam
