as above £100 ono delivered
the carb are really clean also the jets are untouched also the TPS is in place, only bad point there is a small screw missing from the choke slifer but this does not stop the choke operation in anyway
the pump deliveres the right anount of fuel presure (3 psi) for the carbs saves spending loads of a fuel presure reg & a pump
