qwerty
Club RR Member Number: 52
Transporting a windscreen?qwerty
@qwerty
Club Retro Rides Member 52
Well I'm on a windscreen hunt for the Qwertina. I think I've found one but its 155 miles away. We're gunna go and collect it in my mates L200, but we're kinda scared about transporting it. Plan was to have it standing up wrapped in duvets and attatched to the side mounting points...... Any input will be most appreciated. Have some pics.
i took the front and rear screens from a merc 114 down to notts for the Bboy. wedged them both in the back of the old 124 saloon. one hundred and fifty miles later they were both still in one peice.
Hey, I once boffed a hot leper girl, and nothing ever turned rotten and fell off me!
bortaf
Mk4 or 5? Mk4 is toughened and will take a fair whack to shatter it Mk5 are laminated and like an egg in comparrison, whenever i used to transport em on the back of me recovery i straped em to a matress or lump of foam i kept for the purpose then propped the ends up to match the screen curve, made it Derby from London with one no problems don't do the ratchet straps too tight ! just enough to stop it sliding about, those cheap crappy roof racks ones do nicely
R.I.P photobucket
qwerty
@qwerty
Mk5 to replace the Mk4 one bought in error Haha. Hmmm might try to find some foam!
v8ian
The edges have to be protected, get a load of bubblewrap, cover everything. how much room is there at the back of the seat
i normally just chuck windscreens on the back seat of whatever i'm driving and never broken one yet, in a pickup truck i'd wrap it up in a blanket, just avoid bending a laminated screen and it should be fine, glass is pretty strong (stronger than steel in fact) if you don't suprise it.
i put that foam pipe lagging stuff roudn the edges . its the edge that is the weakpoint. Never rest windscreens on the floor , especially on an edge / corner, all that weight in one spot , and its a gonner.
sent screens by courier before, they sometimes make it, sometimes don't.
purplevanman
Way too orangey for crows
glass is pretty strong (stronger than steel in fact) if you don't surprise it. LOL ;D ;D ;D
did you say you got a mk4 one in error ? is it a good one and do you want to sell it my mk3 estate needs a new front screen and mk4's are the same as mk3's ;D my old holden had a new screen in the back with a load of spare the previous owner had brought over from aus with the car it was just in a hoofin great big box with big foam squares in various places to stop it flexing in it
Last Edit: Oct 9, 2009 21:52:22 GMT by Deleted
It's a goodun (and it's taking up space in my garage...) but aint mk4 est and saloon screens different? paging Dr Bortaf to the post... ;D ps. Mk 5 cortina screens break if you look at 'em wrong. Be very, very careful now. (pic only added so Autofive can't )
no they are the same I have a saloon one in there at the mo but its full of scratches mk5 estate are different to saloon as a mk5 estate is just a mk4 with mk5 wings ;D
Last Edit: Oct 9, 2009 22:18:53 GMT by Deleted
well, assuming it's ok with qwerty looks like I have a screen for you no good to me, its def. not the same as a mk2 or a mk3 saloon
well, assuming it's ok with qwerty looks like I have a screen for you no good to me, its def. not the same as a mk2 or a mk3 saloon it'll be the same as mk3 saloon as that's what the van has sadly the one in that is also knackered
Last Edit: Oct 9, 2009 22:52:56 GMT by Deleted
it's not..... (I have checked it against a mk3 saloon)
it's not..... (I have checked it against a mk3 saloon) is it taller or shorter if its taller then its a mk5 saloon screen i have a part numbers list somewhere i'll dig it out but all mk3,4 had the same part number on the base model (no tint) screens
its 1" shorter than a mk5 saloon screen, and is toughened. taller than a mk 3 screen. I'll get you the triplex number tomorrow, cos that's all I know for now.
its 1" shorter than a mk5 saloon screen, and is toughened. taller than a mk 3 screen. I'll get you the triplex number tomorrow, cos that's all I know for now. got me thinking myself now I'll double check on the mk5 estate screen i could be that they may be different but i was sure they where the same as the mk4's (runs off the check parts book )
my mistake the book I have only lists the screen rubbers but there are a few changes in there the mk5 saloon front screen is taller than the mk4 saloon the mk5 estate also has a different rubber than the mk4 estate so I'm guessing the screen is different if yours is taller then would imagine you have a mk5 estate one the mk3 and 4 saloon and estates all list the same screen rubbers so it must be the mk5 estate is also different either way its not gonna fit either of mine jolly pain in the backside but cheer's anyway ;D
Last Edit: Oct 9, 2009 23:52:13 GMT by Deleted
