weber 32/34 twin choke carb [still have box] bought new about 4 years ago but sold the car it was ment to go on. complete with choke cable etc, nuts, bolts, pipes, has jetts fitted but would recomend buying new 1's for your engine aplication [about £1.50 each _ need 4] - suitable replacement for umpteen different motors with little modification or any
aftermarket vw manifold [8v motors 1500 > 1800] mid 70's>90's has no eletric heater [never ment to have 1] takes hot water through base to heat, gas flow much better than the standard set up. has been machined [drilled and taped] to acept webber base plate
the carb and manifold where painted with engine laquer a few years ago but has got chiped in a few places as I have moved it around a couple of hundred times.
& K&N pannel filter to match the carb,
set up was intended for a mk2 golf and would have given a few more horses,
£100 for the lot - located in Scarborough North Yorks - could sort out 48hour courier for about £12.50 and take paypal.
email is tom@gingerdogmanagement.com / mobile 07932 587866
