As title, a pair of 8" Davis Craig fans, used obviously.
i844.photobucket.com/albums/ab6/berger2808/DSC02743.jpg?t=1255879413
After £50 for the pair.
I will dig them out the garage, give them a wipe over and double check that they are all A-OK tomorrow but they should be fine, were working when removed.
Max width including the mounting points etc is 225mm.
Max height (to the nipple in the middle) is 55mm, to the bit around the nipple 50mm.
I'm located in Wigan but get about the North of England with work.
Cheers,
Karl - 07809400883
Cheers,
Karl - 07809400883
