This has been sat under my bench at work for months and i no longer have the car so i guess it's best it gets used. All it needs is it 2 collets which i did have but since lost. It has been bored +40 and has new +40 pistons fitted. I was told the crank was ok when i had the bores done which i trust but that's up to you. It has all the seals and a new water pump. The sump has been modified to suit a 103e Pop crossmember which will need finish welding.
It should be a case of putting it back together and go. I will get some pics up later.
£200ono Which is a lot less than what it's cost me
or £300 with an Aquaplane head
Feel free to make an offer.
