I also have for sale some parts that are surplus to requirements
new unused set of 347ci 4.030"stocker forged trick flow pistons part number TFS-51704110 these were bought in error before I got the stroker kit which came with its own pistons comes with wrist pins and speed pro plasma moly rings £200
also a new MSD pro billet stand alone distributor this distributor will work with or without an ignition booster it can be wired straight to the coil or be run through a booster such as an AL6 ect has bronze drive gear fitted so will work with roller or non roller cam the drive gear pin broke in the shaft when it was fitted but it has been fixed and tested
fits 260,289,302.5.0HO and 351w small block cost £350 new will take SOLD
