Dec 10, 2009 18:54:30 GMT
got some door rubbers to fit soon..they need trimming
the pinch part of the seal is metal incased in rubber , ive always made a pigs ear of cutting these in the past
any ideas for a neat cut ?
Dec 10, 2009 19:50:14 GMT
Angle grinder with a thin cutting disc perhaps ?
life's short & it's hard, like a body building elf.
Dec 10, 2009 20:03:55 GMT
A cutting disc on a Dremel is ideal for that job, much finer disc.
"Was today really necessary?"
87 VW GTi ( MOT PASSED 26/04/10)
2003 Honda cb250y Nighthawk
05 Micra Urbis
purplevanman
Way too orangey for crows
Dec 10, 2009 20:05:34 GMT
i have been cutting armoured lecky cable recently, I put cable over a block of wood, I put a strong knife on the cut line and smack it down with summat weighty good clean cut which may work on your stuff
rodit
Dec 10, 2009 20:31:46 GMT
When we do these at work, as Bruce sias just give it a good sharp chissel.
The alternative we use is a decent sharp set of side cutters and they always seem to do the trick. ;D
Low and slow
Why can't i tune it?
Dec 10, 2009 20:37:58 GMT
thanks for the ideas so far...
side cutters arent gona give me a nice 90deg cut
1mm cutter disc was what i was thinking..if it goes though fast maybe it wont melt much?
keep the ideas coming
Dec 10, 2009 21:13:37 GMT
Bolt cutters or tin snips? No melting but not sure how neat the cut would end up..
Daily: Spazda Mx5
'A52's Fastest steak eater 2010'
mk14dr
Yorkshire and The Humber
Club RR Member Number: 85
Dec 10, 2009 22:13:22 GMT
When I did the door seals on mine earlier in the year, I used a sharp pair of sidecutters and a stanley blade to tidy. All the edges are neat, I even managed to mitre them to 45degs
spiny
Wiki Admin
Club RR Member Number: 167
Dec 10, 2009 23:10:49 GMT
I just used a hacksaw with the seal clamped in the vice
Dec 11, 2009 15:34:44 GMT
used the 1mm cutter disc in a angle grinder after all...did a mint job , nice neat edge with no melting
