ishan
Jan 22, 2010 13:34:37 GMT
bmw156
Jan 25, 2010 16:38:43 GMT
Jan 28, 2010 12:06:42 GMT
Thats a lovely engine crane I've got one just like it Nice motor should have got something mid-engine though ;D
78' Lotus Esprit S1 78' Fiat X1/9 Modsport Racer 99' VW T4 Transporter xx' Triumph/Ducati Bobber
Jan 28, 2010 14:28:50 GMT
Nice project.
So is that the Manta A or B axle then ?
Jan 28, 2010 16:06:58 GMT
B by the sounds of it.
There is no such thing as a curse word car just overstretched expectations................. Herald 10/10 Gasser 10/10 Total score 20/10
bmw156
Jan 28, 2010 17:44:56 GMT
yeh to confirm its a B, 2 inches wider then the chevette.
and the manta A axle i think is about 20mm wider then the chevette axle.
and box file, lol, is nice isnt it...... haha
bmw156
Jan 28, 2010 17:51:59 GMT
ok, i have been doing some research and have found out some good info for the conversion.
to use a XE with a ford type 9 box. i need certain bits from SBD, gave them a call and the guy was very helpful and explained some things to me. parts needed to mate a type 9 to an xe are:
bell housing 7 degree - 154.52 release arm - 32.85 fulcrum pin - 3.96 release bearing - 23.44 spigot bearing - 8.50 a standard XE clutch cover to suit flywheel ( flat or pot) 138.06 and a special 1" x 23 spline clutch plate - 126.33 ( uprated ones available) and a 7 degree manifold for twin 45's is - 94.00
just some useful info for reference.
Jan 28, 2010 18:24:53 GMT
yeh to confirm its a B, 2 inches wider then the chevette. Hmmm . I was always under the impression that if one was to fit the B axle then the wheels would stick out in cartoony Carlos Fandango proportions . But looking at yours , they look fine and dandy to me ! ^ Looking at that it looks like you've got , what , another inch to spare maybe ? Granted , that means you might be only looking at a 6 or 6.5" wheel - give or take offsets - but it's certainly not going to make you reach for the bolt-on arches just yet ! Soooooo why aren't more people using the B axle ? I know the A is supposed to be good for 200bhp ( is it really ? ) but if you pinched a B off a Manta Gte for example then surely it should be capable of handling a bit of power - or am I missing something ? Anyway , didn't mean to turn your thread into an axle debate , keep up the good work man
bmw156
Jan 28, 2010 19:56:46 GMT
debate away, i don't mind, the wheels fitted are the standard alloys, so really skinny and only 155 wide tyres. not sure on the rim width. yeh theres maybe another inch there, i havent got drums on yet, so have to take that into consideration as well. but thats maybe another inch max. but I'm sure i can get a set of 13" x 6 revolutions with a high offset so they will fit under, going to have to measure the space i have and work out my off set that i need. and no idea why people don't use the manta b axle, dertimed to make it fit tho
bmw156
Jan 28, 2010 23:28:19 GMT
Jan 29, 2010 21:08:47 GMT
well, you're progressing well! and gathering the parts at a good rate too! i don't think i've heard anyone say the 'b' axle doesn't fit, just that it makes things tight! only problem i foresee is that you will have to have a play with wheels to find a good offset to tuck them in, especially if you go wider than your 155's on 5 and half rims! which you would really have to do with the extra grunt under the bonnet. that would probably mean you would end up with totally different offsets on your front to back wheels, but you can always buy new wheels in pairs anyway... do the wheels clear the arches now if you heave down on the back end? anyway, sure theres a few of us want to see you complete this mate, now get that axle painted!
Nice car mate The Manta axle was originally designed to take less than 100 bhp so it's pushed at over 130. I had a mancona with a diff and 120 bhp.. slippy diff at a cost of 500 quid and a few doughnuts later .... bang rebuilt it at a cost of 300 quid and i won't use it as i will flog it on and go for an atlas
bmw156
so your saying the manta axle is still to weak? hmmmm
I was going to run english originally, but this manta one came up very cheap and very local, so I couldnt say no!
and thanks for the comments guys, hoppefully it wont be to long befor its done, and I hope to get to a few meets this year.
and yeh about the wheels, I'm looking at new revolutions, which you can specify the offset. so I will probably end up running front and back different. I need to get the drums assembled and work out how much space I have.
things still to buy.
Clutch goodies. custom propshaft megajolt kit engine mounts wheels brakes suspension inlet and exhaust manifolds
lol not much then!
Last Edit: Feb 15, 2010 22:43:47 GMT by bmw156
bmw156
Feb 15, 2010 22:43:16 GMT
NOM
lotdave
only one gerry
Feb 15, 2010 23:34:59 GMT
Always glad to help a fellow retro builder and i do remember looking at your car before its a minter are you getting the carbs jetted for the xe, do you know what they were fitted to before? ill keep an eye on your progress ;D
bmw156
the carbs were fitted to a 2.0l zetec, so that should be good enough to get me running, then ill set them up.
bmw156
Feb 26, 2010 18:07:54 GMT
ok i have done alot of work to this, but keep forgetting to update this thread. alot of pics: Flywheel on, with ARP's Clutch also on and aligned. so just to keep me busy i rebuild the carbs. not many pics as i couldnt be arsed, but i had all the bits layed out on paper and numbered lol. and they were very clean inside, and fitted all new gaskets. as i don't think i will ever find a manta big wing sump. i have decided to make my own from a 8v steel sump. so to get a rough idea and shape, i have made it out of card first, very rough. but i think it has come out alright. Can ya guess what it is yet, nice pile of bits and mocked up sort off lol.
craig
Feb 26, 2010 19:41:07 GMT
Looking good, are you working in the driveway/house? Where did you get the exhaust bends? Need to sort mine out somewhen.
bmw156
Feb 26, 2010 20:27:24 GMT
I'm working in a very small shed lol and on the drive.
and on ebay ashley exhausts did that as a whole package ready to weld together.
was 100 quid, and came with all the bits your can see.
carmad
I'm working in a very small shed lol and on the drive. and on ebay ashley exhausts did that as a whole package ready to weld together. was 100 quid, and came with all the bits your can see. have you a link for that ??
