MrBen
The enquiry is complete The vehicle details for K25 RAF are:
Date of Liability 01 08 2007 Date of First Registration 13 09 1988 Year of Manufacture 1988 Cylinder Capacity (cc) 1597CC CO2 Emissions Not Available Fuel Type Petrol Export Marker Not Applicable Vehicle Status Unlicensed Vehicle Colour RED Vehicle Type Approval
Registered 1988, but now on a K plate - looks like a DVLA cockup rather than a late registered car...
Toy: 2001 Porsche Boxster S - almost retro! Daily: Modern BMW 435i - less exciting but quick!
grant
Aww that was intresting untill you did the check. Still cool to run around with a K plate! How is it you do the above check I can never find it properly on the dvla site^^^^
hopfully swansea might but another k reg back on it??!! I imagine they would - it's unlikely that they'd go scratching around in the whys and wherefores of each car's plate when they can just do a like-for-like swap. I bet that since it's on a K-plate, they'd issue another K-plate.
Nathan
Club RR Member Number: 1
XR2 help me decide!Nathan
@bgtmidget7476
Club Retro Rides Member 1
Jan 12, 2010 10:34:06 GMT
OK As the capri is up for sale the itch for one of these has gone into over load.
No i know they can rot, but what are the Standard xr2's like performance wise etc, and how easy is the Zetec swap (Missus is gonna kill me if I buy one but who cares).
orangecords
yawner extraordinaire
Jan 12, 2010 10:48:27 GMT
I have lost the will to live repairing mine. I need parts bad and cant find them! love that car too got a guy that wants it bad but doesnt want to pay me the silly figure I keep saying to put him off plus after a not very nice split from the ex in august it would appear i cant find the log book anyway
I then wanted to start cleaning the interior as it stinks of wood (the material not the smell of a boner) best quote ever!
Darrel
Jan 12, 2010 11:10:20 GMT
As part of my apprenticeship we had a day out to Ford Dagenham in 1992. Saw all the new Fiestas being made there. was an amazing day out. Funnily enough I saw unsold Xr2's in the car park. Even though they stopped production in 1989 i think they took a while to sell off all their old stock bearing in mind the Xr2i was same price but more powerful. Date of manufacture at date of first registration can be a completely different thing.
kee
Jan 12, 2010 12:03:32 GMT
OK As the capri is up for sale the itch for one of these has gone into over load. No I know they can rot, but what are the Standard xr2's like performance wise etc, and how easy is the Zetec swap (Missus is gonna kill me if I buy one but who cares). zetec conversion is very easy. use the same gearbox, buy a mount for about £40-60 and there you have it bolted in. need an ERST clutch, zetec fly. also need 1800 sump, water pump etc. then the induction is up to you, there are fuel injection tanks available for a mk2 which makes life easier, just the wiring then
XR2 help me decide!HARDCORE
@hardcore
Club Retro Rides Member 190
Jan 12, 2010 12:06:21 GMT
How easy is it in a Mk1 Kee? Does it very from Zetec to Zetec?
HC.
kee
Jan 12, 2010 12:11:26 GMT
yeah, the early zetecs are easier as the waterpump goes the right way. later zetecs need a tensioner to spin it the opposite way. no difference performance wise though. as for into a mk1, i should be doing it this summer. it depends what you want, i'm staying 4-speed. a 5-speed box needs the chassis legs cutting out and strengthening to make room for the 5th gear. the zetecs bolt to any old ford 4 pot gearbox there are no mounts available so its a custom mount job, but they aren't too complex. some people cut a bit of clearance in the off side chassis rails as its a bit close, but with decent engine mounts this can be left, hopefully ;D from then on its whatever induction you like and sorting the exhaust. lots of little bits to sort to make it better, i have a list of stuff to buy and its adding up. alternator clearance can be a curse word as can exhaust downpipe clearance if using a 4-speed box with front mount starter. all this i will be finding out, i plan to have it running fine by RRG10 ;D
@hardcore
Jan 12, 2010 12:15:52 GMT
Sounds good to me dude I reckon the Mrs' little 950 will need an overhaul come the summer (when I've got some of my fleet back in one piece!) I've been offered a Puma engine (1.7 16v) - any good? HC.
Jan 12, 2010 12:18:39 GMT
I've been offered a Puma engine (1.7 16v) - any good? A lot of people put these in mk5 Fiestas - supposed to be quite a willing little lump.
kee
Jan 12, 2010 12:19:52 GMT
if you can fabricate stuff, yeah. i'd love to fit one of those, gearbox bolt pattern is different so you'd need to use the puma box and chop the chassis rails up. also custom driveshafts are needed and clearance of inlet and exhaust will be a pain as they are the opposite way round. you may have troubles with having a 950 engine, too. it can be done with the 950 stuff but hasn't. the gearbox cradle is different and the driveshafts aren't as good. not sure how as i've never really looked into it, mine is a 1300. if you need more info/advice go sign up to www.fiesta-mk1.co.uk and www.xrtwo.com lots of chaps done the conversion succesfully. only one did the puma engine and didnt finish it lots of work was needed as he never used a gearbox cradle.
kee
Jan 12, 2010 12:22:16 GMT
the puma engines aren't any good for tuning as they have variable cam timing. the 1.6's are good for 220bhp on standard valve sizes.
theres a chap on turbosport with a 1.4 mk5 fez running 167bhp on standard crank and rods ;D
@hardcore
Jan 12, 2010 12:30:38 GMT
Hmm.. might give that a miss then!
What's the 'optimal' Zetec? (in terms of ease of fitting & tunabilty) I've got bike carbs I'd be running it on more than likely..
I'd always figured on having to replace the 'box & shafts anyway, 950 ratio's would probably be terrible with a 2ltr Zetec (hilarious but terrible!)
HC.
kee
Jan 12, 2010 12:32:43 GMT
hilarious, yes ;D
i was gonna use my 1300 but got a 1600 with lsd now ;D
eaiest to fit is a 1.8 zetec from an escort, fiesta or mk1/2 mondeo. from focus onwards are the series 3 with the stupid waterpump. got mine from ginetta with less than 2k on the clock.
@hardcore
Jan 12, 2010 12:43:29 GMT
hilarious, yes ;D I was gonna use my 1300 but got a 1600 with lsd now ;D eaiest to fit is a 1.8 zetec from an escort, fiesta or mk1/2 mondeo. from focus onwards are the series 3 with the stupid waterpump. got mine from ginetta with less than 2k on the clock. That sounds like a win - they come up often? (the 1600 LSD 'box) Why you going for a 4-speed? Easier fitting? Is an 1.8 not the same as 2l? (fitting-wise) Ginetta lump sounds awse! They modified at all? Are they readily available (& pricey!)? Thanks dude - sorry for the epic thread hijack (ish, might be of some help!) HC.
kee
Jan 12, 2010 12:52:43 GMT
ginetta have lots of engines still available, at a damn good price. no ancillaries though.
i don't weld and don't wanna chop the chassis rails, planning on racing in a class where shell mods aren't allowed in the future, so i can put my x/flow back in. the 2.0s have sump bowl on wrong side and i think the water pump needs to be changed to 1.8, not much to do though.
the lsd came from a s1 rst and can be fitted easily, apparently.
kee
Jan 12, 2010 12:53:43 GMT
and the ginetta engine is standard but with custom inlet gubbins and modified sump which I'm swapping for a 1.8 sump and pickup. sump can be sold for use on a kitcar though
@hardcore
Jan 12, 2010 13:03:16 GMT
Cool ;D I look forward to following your progress (then copying it, lol ) You got contact details for Ginetta you can pass on? I've got no issues with chopping & welding chassis rails ;D HC.
kee
Jan 12, 2010 13:18:12 GMT
google is your friend, ginetta cars
